What date code for alt and starter 69 GTX? #3015574
02/15/22 12:30 AM
02/15/22 12:30 AM
Someplace you aren't
SomeCarGuy Offline OP
This is the first car I’ve had where I find myself caring about such things. The parts like manifolds and carb and distributor are all the correct part numbers. The intake for my Dec 5th SPD Lynch Rd car says 11/27/68 on it. I figure the starters and alternators were a bit before that? What is acceptable and where on them do I look for date codes? The alt has a reman sticker right on the top so I assume it will be incorrect.
I want my fair share
Re: What date code for alt and starter 69 GTX? [Re: SomeCarGuy] #3015581
02/15/22 07:43 AM
02/15/22 07:43 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Something in the same Oct or Nov time frame
Re: What date code for alt and starter 69 GTX? [Re: gtx6970] #3016125
02/16/22 07:26 PM
02/16/22 07:26 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
do a google search for mopar alt./starter date codes,you will figure out how to decode from the results.
Re: What date code for alt and starter 69 GTX? [Re: 71GTX471] #3016215
02/17/22 07:13 AM
02/17/22 07:13 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Once you start down the OEM date code path, you tend to want more and more....
Electrical components are usually dated by week/year. So a 12 9 (starter barrel) or 12 69 (alternator stamp pad) code is the 12th week of 1969. Inventory management in 1969 was nothing like it is today. A window of 6 to 2 weeks prior to production date is considered acceptable for the parts you are looking for.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: What date code for alt and starter 69 GTX? [Re: Big D A12] #3016316
02/17/22 02:47 PM
02/17/22 02:47 PM
Thanks I’ll do some checking on what I have laying around the garage.
Re: What date code for alt and starter 69 GTX? [Re: SomeCarGuy] #3027243
03/24/22 10:36 PM
03/24/22 10:36 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Went through same drill with daughter's 69 Charger. Alternator was an incorrect squareback replacement. So started searching for correct part# alternator dated about 4wks ahead of build date. Also advertised here in WTB. Fortunately moparts member had non-working one with correct part# and date codes. Rebuilt using NOS stator and internals from a parts store remanufactured unit.
Re: What date code for alt and starter 69 GTX? [Re: SomeCarGuy] #3027272
03/25/22 12:40 AM
03/25/22 12:40 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
What's the date on the K-frame?
Re: What date code for alt and starter 69 GTX? [Re: A12] #3028540
03/28/22 11:28 PM
03/28/22 11:28 PM
I don’t know, I’ve never cared about such things before this car. Don’t even know where to look for a k frame date code.
Re: What date code for alt and starter 69 GTX? [Re: SomeCarGuy] #3028559
03/29/22 05:04 AM
03/29/22 05:04 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Your SPD of 11/27/69 is calendar day 332
Calendar day by number 1968 link
Your K-frame date will usually (but not always) be the closest day to your SPD that has been found on other Lynch Road assembled car's SPD's. As stated "usually" but NOT always. Would just be interesting to see what your K-frame stamped date is. It's located on the front of the K-frame (see photo with text) and just a guess it might be 328 8 1 or day of the year 328- Nov. 23, "8" =1968 and "1" = first shift. And that's a WAG (wild @$$ guess) grin
119 9 1 in the second photo = April 29, 1969 Shift 1
139 9 1 = May 19, 1969 Shift 1
K frame date code 1429 1 c 640x480 with text.jpgK-frame 119 9  1 date code 1.jpgDSC07878.JPG
Re: What date code for alt and starter 69 GTX? [Re: A12] #3031730
04/08/22 12:16 AM
04/08/22 12:16 AM
Was under there today and looked at the k. Couldn’t see any stampings. Will try and clean it and see if there are any. It’s really not dirty though.
Definitely an early one as it has no holes drilled for the 70 sway. Not even predrilled.
