Page 2 of 4 1 2 3 4
Re: Engine Masters 440-6 vs 426 Hemi [Re: moparx] #3014690
02/12/22 01:49 PM
02/12/22 01:49 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Good analogy...
Joe
Re: Engine Masters 440-6 vs 426 Hemi [Re: GomangoCuda] #3014693
02/12/22 01:56 PM
02/12/22 01:56 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I would have liked this comparison more if the hemi didn't have a Stage 5 single plane intake with who knows what size Holley carbs and $4000 Barton rockers. Put a stock dual plane intake and carbs and stock rockers on it and rerun the test. Even better, put that cam in a stock streethemi. That would be more comparable with Dulcich's 440. Heck the intake and rockers on that hemi are worth more than Dulcich's whole engine.
Re: Engine Masters 440-6 vs 426 Hemi [Re: GomangoCuda] #3014698
02/12/22 02:23 PM
02/12/22 02:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I want to see a comparison where they make the CID identical, then there won't be no comparison. People always ignore the fact the hemi was down 14 CID, that alone would be close to 20 LBS TQ and hand the advantage to the hemi as down low it would no longer lack the TQ advantage the 440 had as well as running away as the RPM went up.
Re: Engine Masters 440-6 vs 426 Hemi [Re: moparx] #3014699
02/12/22 02:25 PM
02/12/22 02:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
The six pack cars were made to compete with the BB Chevy on the street twocents scope
So where the street hemi cars shruggy
Re: Engine Masters 440-6 vs 426 Hemi [Re: Cab_Burge] #3014711
02/12/22 03:07 PM
02/12/22 03:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Interesting comparison, seemed to me, but they left power on the table with only 9:1 on the Hemi.
I'd prefer to see each one built more to their strengths as you would with a fresh build, but it was still good data.
The low-end TQ comparison is pretty valid; my Street Hemi was pretty "average" on the butt-dyno under 3500 RPM.
After 3500 though, it rapidly charged towards 7500 with a vengeance, and was still pulling when I'd hit the next gear.
On the dyno, it pulled 490 TQ, 540 HP before the AFBs were sorted out. Pretty decent in 1988.
Mostly stock, but + .060, 10.8:1, old-school Crower solid FT (.547 lift, 300 adv duration is all I recall now), headers, MSD, 8-qt Milodon pan & ported stock heads.
My 440s with similar mods have been snappier under 3500, which seems to be the heads (Eddys or Stealths, but not as much port size & CFM of course as the Hemi).
My 512 with Indy EZ top-end was pretty much a blend of both architectures; one of its strengths was being happy with a 3.23 gear, where the Hemi wanted 4.10s for all-around street/hwy use.
None of them were what I'd call fussy to maintain - so I'd say that knock on the Hemi's rep is from poor tuning.
Re: Engine Masters 440-6 vs 426 Hemi [Re: Cab_Burge] #3014712
02/12/22 03:10 PM
02/12/22 03:10 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The test is interesting, but I have my own opinions of course. Number one, why would anybody in their right mind run a Hemi at 9 to 1 compression? It makes absolutely no sense unless you live in a third world country where you can only get some kind of junk fuel. Number two, why would you try and run identical cam profiles on two engines with such radically different cylinder head configurations. Putting a dump truck cam like that in a Hemi is like requiring an Olympic runner to breathe through a straw.
I think a better test would be put together a couple of bone stock engines, blueprinted to the original published specifications. No porting, no trick valve job, no fancy valves, stock pistons, rods, cranks, everything. Just put in some good rod bolts for insurance. Blueprint the assembly process to make sure that manifolds and carburetors and everything fits properly, blueprint and tune the carburetors and distributors, to make sure that each engine is in optimized stock configuration. Then dyno test them that way and and see what you get. Then add camshaft with matching springs and headers. Rather than try to equalize, put in the optimum cam and header for that particular engine. Then test them again and see what you get. Then pick another modification, like intake manifold and carburetors. Again, don't equalize, optimize for the combination. Then you get an idea of what the stock long block is capable of for each motor. Then if you want to take it further add compression and head porting. But don't equalize compression, pick an octane and optimize compression for each engine to run on that octane.
Then I think we'd have some testing and a comparison that is actually really meaningful. Of course I realized that this is a TV show, and they had to pretty much run stuff that they had sitting around. They had no incentive whatsoever to do a test such as I suggest. Just the fact that they are doing the comparison will bring in enough viewers to satisfy the producer.
Everybody's speculation that the Hemi is slower on the first half of the track and faster on the top end of the track in my opinion has nothing to do with the power band / torque curve of the engine. That entire fallacy assumes there is no transmission and that you are making a drag strip run like a dino pull in high gear. Everybody seems to forget that the engine will hit red line three or four times by the 8th mile.
I think it has more to do with gearing and traction on street tires. Obviously, in all iron Hemi is very heavy. Getting one off the line on street tires can be a challenge. And most street Hemi cars aren't geared deep enough. If everything is optimized, including gearing, traction, and removing driver error, the car with the better power to weight ratio will always win in a drag race.
The third thing is that a Hemi needs constant tuning. That is a total crock. It takes No more effort to keep a Hemi in tune than any other car with dual points, solid cam and two carburetors. It's no big deal whatsoever and once it is dialed in, the need to change or adjust anything is very seldom.
Edit: top side it looks like you and me were thinking the same thing and type in the same thing at the same time!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Engine Masters 440-6 vs 426 Hemi [Re: Hemi_Joel] #3014723
02/12/22 03:59 PM
02/12/22 03:59 PM
Joel, you're talking real world results and testing. up
Not like the "theory" guys that make up these tests and get paid to write their results shruggy
I always take each one of these articles with a grain of salt, you have to remember that the people writing the articles are writers that may or may not like or know anything about cars and motors work devil
Re: Engine Masters 440-6 vs 426 Hemi [Re: Cab_Burge] #3014729
02/12/22 04:14 PM
02/12/22 04:14 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Well the one thing no one mentioned was that the 440six is going to go in Steve's charger that is at the farm.
So looks like a great Roadkill episode or 2 is on the way.
The 440 with six-pack was what he had on hand as is for his own car.
So yes you can say the Hemi was under built but was needing to be close to what the street driven 440 he has planed. If that makes sense?
Anyway I think it was a 71 or 72 so it should be a blast when they drop it in.
And the way he drives I hope they have lots of spare tires when they test.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Engine Masters 440-6 vs 426 Hemi [Re: 340SIX] #3014736
02/12/22 04:45 PM
02/12/22 04:45 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Still makes no sense to me. That was the right cam for a street 440. Not for the Hemi.
When the 440 in this test hit is limit, the obstruction was the heads. But it was actually a very well matched combo. What is the the one thing that sets the Hemi apart? The heads. But the heads weren't tested in this test, the cam was a bottleneck that didn't let them breath. The heads and the intake are both capable of delivering way more, so it was a very mismatched package.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Engine Masters 440-6 vs 426 Hemi [Re: Hemi_Joel] #3014746
02/12/22 05:38 PM
02/12/22 05:38 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
thats the first thing i thought, how do you have the same cam profile for a 440 and a hemi, if it were a good cam for the hemi it would have not been for the 440, i think they said the compression was about a half point lower for the hemi which did not help it, they did not prove anything that we all did not already know, but it sure was entertaining.
Re: Engine Masters 440-6 vs 426 Hemi [Re: Hemi_Joel] #3014748
02/12/22 05:57 PM
02/12/22 05:57 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
They also keep saying no torque on the Hemi, well dump the clutch at 4500 and see what engine wins. Real world times with our 68 Dart drag car, 440 had stock heads .030 over 11.1 pistons and mild roller 590 cam 850 DP car ran 6.80s. With stock bore Hemi 12.1 pistons 550 RB roller cam stock heads and cross ram intake two hollys same vert ran 6.60s 1/8 mile. Now 1/4 440 was 10.90 Hemi 10.31 poping running out of fuel, now that’s a back in the day bonafide test. Car and motor (440) weighed 3100. Kenny was 250, This was 1980
Re: Engine Masters 440-6 vs 426 Hemi [Re: cudaman1969] #3014754
02/12/22 06:18 PM
02/12/22 06:18 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Rock , Flip Over
This test was done back in June of 2021
Snooze
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Engine Masters 440-6 vs 426 Hemi [Re: bee1971] #3014758
02/12/22 06:24 PM
02/12/22 06:24 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Siberian Huskies
Re: Engine Masters 440-6 vs 426 Hemi [Re: SV_MOPARS] #3014773
02/12/22 07:05 PM
02/12/22 07:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
the Street Hemi girnd cam DC used to sell seemed to work pretty good in my 413.
Re: Engine Masters 440-6 vs 426 Hemi [Re: Sniper] #3014840
02/12/22 10:07 PM
02/12/22 10:07 PM
are you talking about the Mopar Purple Shaft 284 street Hemi grind cam in your 413?
If so you may want to try another better grind, I hated those cams in wedges down tsk
Re: Engine Masters 440-6 vs 426 Hemi [Re: Cab_Burge] #3014847
02/12/22 10:16 PM
02/12/22 10:16 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I am not sure that is a fair assessment of Freiburger, Dolcich, or Brule.
Master, again and still
Re: Engine Masters 440-6 vs 426 Hemi [Re: DaveRS23] #3014881
02/13/22 12:48 AM
02/13/22 12:48 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
These 3 guys are not your typical automtive press. All three of them are VERY sharp and very experienced in high performance engines. But still, they are producing a TV show. They have deadlines and budgets and producers.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Engine Masters 440-6 vs 426 Hemi [Re: Cab_Burge] #3014888
02/13/22 01:57 AM
02/13/22 01:57 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I loved the Mopar 280/.474 cam in my 9.5 compression 440. Ran it in a 67 b-body with 3.91 gears, factory high stall convertor, HP manifolds, Weiand 8009 intake with a 750 Holley. Sucker ran hard. 13.00 @ 117mph. Ran hard enough to get me a $1275 ticket one evening.
Re: Engine Masters 440-6 vs 426 Hemi [Re: elmor353] #3014893
02/13/22 03:42 AM
02/13/22 03:42 AM
My personel experiences with that cam back in the late 1990s was really bad, I degree it for the shop in the customers 1968 Charger 383 automatic car, that cam wouldn't make enough manifold vacuum idling at a stop light to stop twice, NOT GOOD down It had a nasty sounding idle and didn't pull real hard down low or anywhere else whiney I degree it where Mopar advice on that cam back then wrench I think they replace that cam part number with a similar grind several years later to make it better scope
The shop owner removed it after driving it once and put in a "R.V" cam that would stop it okay.
The 19-year-old owner wrap it around a power pole within 6 weeks of getting it back whiney
I never sold another one of those cam kits, NEVER down
Re: Engine Masters 440-6 vs 426 Hemi [Re: Cab_Burge] #3014909
02/13/22 08:37 AM
02/13/22 08:37 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Ditto, had one in the mid '70's, no idle vacuum. IIRC, it was discontinued and replaced with a different "hemi grind" because it hurt the low end so badly and the top end was hardly improved over the stock cam.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Page 2 of 4 1 2 3 4
