Re: indy roller rocker failure
[Re: AndyF]
#3015315
02/14/22 11:52 AM
02/14/22 11:52 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Whoever put the valvetrain together wasn't paying attention. Better pull the whole engine apart and check everything. Agreed. Thread should be titled "engine builder failure"
[Re: Furys]
#3015343
02/14/22 01:24 PM
02/14/22 01:24 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Dodged a bullet, could have been much, much worse.
Who knows what else is messed up?
Tear the whole thing down and start over.
Rich H.
Esse Quam Videri
[Re: sasquatch]
#3015344
02/14/22 01:24 PM
02/14/22 01:24 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Yes I agree it needs to come out. Your rocker tip alignment is whack. MOST likely due to a pushrod rubbing problem that is common to those rockers. Instead of grinding for clearance they just moved the tip halfway off the valve. You need lash caps as well from the looks of it, again fairly common on hemi engines. From the looks of it you most likely got lucky that it did not drop a valve. Todd with this and all statments made prior...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
