Thread lock on cam gear bolts? #3014203
02/11/22 12:46 AM
02/11/22 12:46 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Which thread locker you guys using on cam gear bolts or is it needed?
Re: Thread lock on cam gear bolts? [Re: mopar dave] #3014206
02/11/22 12:52 AM
02/11/22 12:52 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I always use blue loctite.
Re: Thread lock on cam gear bolts? [Re: rickraw] #3014211
02/11/22 01:11 AM
02/11/22 01:11 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Red for me.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Thread lock on cam gear bolts? [Re: pittsburghracer] #3014239
02/11/22 09:24 AM
02/11/22 09:24 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Blue for me. But I have only stock, or slightly warmed over, engines.
Re: Thread lock on cam gear bolts? [Re: 6PakBee] #3014256
02/11/22 10:29 AM
02/11/22 10:29 AM
Mt Morris Michigan
Mt Morris Michigan
I have always used blue, but seen others using red. Thought i would post it up here to see. I never had anything come loose using blue. Thanks
Re: Thread lock on cam gear bolts? [Re: mopar dave] #3014261
02/11/22 10:56 AM
02/11/22 10:56 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
BLUE
Re: Thread lock on cam gear bolts? [Re: cl440] #3014289
02/11/22 12:11 PM
02/11/22 12:11 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
RED
Re: Thread lock on cam gear bolts? [Re: VernMotor] #3014298
02/11/22 12:36 PM
02/11/22 12:36 PM
PA.
"Little"John
"Little"John
PA.
But then again I use red on transmission pan bolts, converter bolts, axle studs, and my breakfast cereal too. Lol πŸ˜‚
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Thread lock on cam gear bolts? [Re: VernMotor] #3014312
02/11/22 01:04 PM
02/11/22 01:04 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Originally Posted by VernMotor
RED
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Thread lock on cam gear bolts? [Re: pittsburghracer] #3014365
02/11/22 02:47 PM
02/11/22 02:47 PM
moparx Offline
moparx  Offline
what does it make your cereal taste like ? does it make you "CooCoo for CocoPuffs" ? biggrin
beer
Re: Thread lock on cam gear bolts? [Re: moparx] #3014377
02/11/22 03:06 PM
02/11/22 03:06 PM
PA.
"Little"John
"Little"John
PA.
beer
It’s kinda bland on cereal but when it drips off a converter bolt right into your mouth it makes you kinda tite-lipped.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Thread lock on cam gear bolts? [Re: W.I.N. Racing] #3014385
02/11/22 03:18 PM
02/11/22 03:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
RED
iagree
I use red until I broke off one bolt on a 3 bolt cam trying to change the ILC, whiney
I use blue now up
Re: Thread lock on cam gear bolts? [Re: mopar dave] #3014437
02/11/22 05:40 PM
02/11/22 05:40 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Have used BLUE in the past, but now I picked up some ORANGE and used on my oil pan studs (hated the thought of these things backing out on me with the engine already installed in the car).
So I'm actually contemplating using ORANGE for the cam bolt now.
Also, speaking of using thread-lock (not meaning to hijack the thread '@mopar dave'): are you guys using anything on the oil pump pickup-to-pump body?
I haven't used anything before, but now it feels like I should...???
Re: Thread lock on cam gear bolts? [Re: pittsburghracer] #3014499
02/11/22 08:14 PM
02/11/22 08:14 PM
Mt Morris Michigan
Mt Morris Michigan
You want to be sure it doesn't come apart on its own. What is the torque spec on those bolts? Gonna see what i can get done tomorrow. I need to get cam button installed and set up for clearance(what claerance do you guys like between button and cover?) Need to check piston/valve clearance and map cam lobes as well. Would be nice to get all the new springs installed too, but i doubt i get that far.
Re: Thread lock on cam gear bolts? [Re: mopar dave] #3015150
02/13/22 09:15 PM
02/13/22 09:15 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How about safety wire? Seems to be popular on aircraft parts... work
Re: Thread lock on cam gear bolts? [Re: mopar dave] #3015156
02/13/22 09:26 PM
02/13/22 09:26 PM
On cam end play have .015 to maybe .030, any more than that look at the oil pump drive gear real closely twocents
My 1969 FSM calls for 35 Ft lbs. on the 3 bolt cam bolts in the Hemi motors up That is what i use on all my 3/8 cam bolts wrench
Re: Thread lock on cam gear bolts? [Re: DrCharles] #3015157
02/13/22 09:28 PM
02/13/22 09:28 PM
the cam rotates clockwise which trys to tighten those bolts , not loosen them work scope
Re: Thread lock on cam gear bolts? [Re: Cab_Burge] #3015263
02/14/22 09:25 AM
02/14/22 09:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My experience. Never had trouble getting anything apart with red. A little propane heat if if its really stuck. My Will wood rotor were safety wired to the hubs. They were also supposed to be attached with Locktite red. These had been in use for years. On the hoist one day my son bumped the tire causing it to rotate just slightly. I noticed the rotor lagged behind. This hub did not have locktite. It was only safety wired. The bolts and wire had stretched slightly. The wire kept the bolts from falling out. But it did not keep them from coming loose. All bolts were torqued during assembly. New bolts, locktite and safety wire now.
Doug
Re: Thread lock on cam gear bolts? [Re: mopar dave] #3015271
02/14/22 09:36 AM
02/14/22 09:36 AM
an8sec70cuda Offline
Red loctite here.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Thread lock on cam gear bolts? [Re: Diplomat360] #3015622
02/15/22 12:12 PM
02/15/22 12:12 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
https://www.homedepot.com/p/Permate...YcAtyo_hhcaAtiuEALw_wcB&gclsrc=aw.ds
The new and improved Blue
Or is it the new and improved Red
Are you afraid to use Red Thread locker, but need a product stronger than Blue. Permatex has developed a 1-of-akin product that combines the high strength of Red Thread locker, with the removability of Blue Thread locker. Introducing High Strength Removable Orange Thread locker. With 3 x the strength of Blue Thread locker, this hybrid formula is great for high vibration applications and will not loosen or back out over time.
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
