Re: Thread lock on cam gear bolts?
[Re: pittsburghracer]
#3014239
02/11/22 09:24 AM
02/11/22 09:24 AM
Posts: 10,755 North Dakota
6PakBee
North Dakota
Blue for me. But I have only stock, or slightly warmed over, engines.
[Re: VernMotor]
#3014298
02/11/22 12:36 PM
02/11/22 12:36 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
But then again I use red on transmission pan bolts, converter bolts, axle studs, and my breakfast cereal too. Lol π
[Re: VernMotor]
#3014312
02/11/22 01:04 PM
02/11/22 01:04 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: moparx]
#3014377
02/11/22 03:06 PM
02/11/22 03:06 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
what does it make your cereal taste like ? does it make you "CooCoo for CocoPuffs" ? Itβs kinda bland on cereal but when it drips off a converter bolt right into your mouth it makes you kinda tite-lipped.
[Re: mopar dave]
#3015156
02/13/22 09:26 PM
02/13/22 09:26 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
On cam end play have .015 to maybe .030, any more than that look at the oil pump drive gear real closely My 1969 FSM calls for 35 Ft lbs. on the 3 bolt cam bolts in the Hemi motors That is what i use on all my 3/8 cam bolts
[Re: mopar dave]
#3015271
02/14/22 09:36 AM
02/14/22 09:36 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: Diplomat360]
#3015622
02/15/22 12:12 PM
02/15/22 12:12 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Have used BLUE in the past, but now I picked up some ORANGE and used on my oil pan studs (hated the thought of these things backing out on me with the engine already installed in the car).
So I'm actually contemplating using ORANGE for the cam bolt now.
Also, speaking of using thread-lock (not meaning to hijack the thread '@mopar dave'): are you guys using anything on the oil pump pickup-to-pump body?
I haven't used anything before, but now it feels like I should...??? https://www.homedepot.com/p/Permate...YcAtyo_hhcaAtiuEALw_wcB&gclsrc=aw.dsThe new and improved Blue Or is it the new and improved Red Are you afraid to use Red Thread locker, but need a product stronger than Blue. Permatex has developed a 1-of-akin product that combines the high strength of Red Thread locker, with the removability of Blue Thread locker. Introducing High Strength Removable Orange Thread locker. With 3 x the strength of Blue Thread locker, this hybrid formula is great for high vibration applications and will not loosen or back out over time.
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
