Re: 1970 SE challenger rear window plug installation question
[Re: todd440]
#3014923
02/13/22 09:31 AM
02/13/22 09:31 AM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
I just took mine apart, mine didn't have anything to seal the plug either, had some type of foil tape over the screws and jute type material around the plug to take up the gap. it seemed odd to me it didnt have anything to seal the plug but thats what i found.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
[Re: moparfan]
#3014930
02/13/22 09:53 AM
02/13/22 09:53 AM
Posts: 6,394 Abilene, Texas
fastmark
Abilene, Texas
That’s what I found in the one I had. The tape is the same kind I use on hvac ductwork.
[Re: fastmark]
#3015066
02/13/22 03:41 PM
02/13/22 03:41 PM
Posts: 1,978 USA
Suregrip391
USA
Here’s how I did mine, used the foil tape as previously mentioned and used some closed cell foam to bring the surface back up before putting the new top down.
[Re: Suregrip391]
#3015392
02/14/22 03:16 PM
02/14/22 03:16 PM
moparfan
Marysville Wa
Let us know how the top looks. seems like the indents under over the screw openings would show thru the top with out anything, My car originally had some type of white material over the plug.
[Re: moparfan]
#3015556
02/14/22 11:04 PM
02/14/22 11:04 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
Well, if you just bondoed it in, would the bondo crack? Seems to me like there would definitely be some filler used to smooth it all out. I figure there will be movement between the filler plug & the original roof & twolip panel.
[Re: Sunroofcuda]
#3016412
02/17/22 10:00 PM
02/17/22 10:00 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Well, if you just bondoed it in, would the bondo crack? Seems to me like there would definitely be some filler used to smooth it all out. I figure there will be movement between the filler plug & the original roof & twolip panel. The original plug was put in really shabby since Ma Mopar figured the vinyl top would keep the plug and filler padding dry. I am not sure if bondo would be a good choice under the top because it would be a pain to fix it later if it ever needed it. If you wanted a small window without a vinyl cover you could try it but I would think the metal/plastic plug and bondo would crack do to the uneven expansion when in the summer heat or winter cold. It would be interesting to see a small window without the vinyl top. I think it would be subtle and not the first thing noticed but unique too.
