Spring perches - which ones? #3011321
02/01/22 09:12 PM
02/01/22 09:12 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
Car has caltracs, monoleafs, dana60, dot drag radials
https://www.doctordiff.com/leaf-spring-perches-pair.html ---------- Looks oem $15
https://calvertracing.com/product-categories/parts/ ---------- Looks stronger $50
Re: Spring perches - which ones? [Re: GomangoCuda] #3011344
02/01/22 09:58 PM
02/01/22 09:58 PM
Your choice up
i have collapse a stock 8 3/4 axle housing at the spring perch when I had issues with broken plates on the stock 8 3/4 early clutch type posi unit, the posi would slip a tiny bit and then hit a like stick shift dropping the clutch, very violent: tsk
Stronger can't hurt twocents work:
Re: Spring perches - which ones? [Re: GomangoCuda] #3011464
02/02/22 10:11 AM
02/02/22 10:11 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Moroso 85090 is also decent option.
Rich H.
Esse Quam Videri
Re: Spring perches - which ones? [Re: GomangoCuda] #3011537
02/02/22 12:59 PM
02/02/22 12:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I just bought a set of the Summit Brand perches. I do plan on boxing them, which was originally recommended by Calvert.
Re: Spring perches - which ones? [Re: ZIPPY] #3011538
02/02/22 12:59 PM
02/02/22 12:59 PM
moparx Online content
moparx  Online Content
or just box in the OEM perches ? shruggy
super easy to do and cheap as well.
beer
Re: Spring perches - which ones? [Re: moparx] #3011585
02/02/22 03:00 PM
02/02/22 03:00 PM
beer
I don't have any perches on it at this time. The Dana60 came from some Camaro guy that cut them off and welded on some kind of housing floater brackets and never got any further with his project. At least he didn't get ladderbar or fourlink brackets welded on for me to grind off. I've got the floater brackets ground off and just need some spring perches.
So what I was really asking about was since I am working with a clean slate should I get the stronger brackets made for the Caltracs or are the OEM style adequate? I have never bent one but then I have been kind of babying the 8 3/4 for years. This is just a Street/Strip toy like many on here.
Re: Spring perches - which ones? [Re: GomangoCuda] #3011613
02/02/22 04:22 PM
02/02/22 04:22 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
US CAR TOOL he's a moparts sponsor, also boxed
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Spring perches - which ones? [Re: GomangoCuda] #3011619
02/02/22 04:27 PM
02/02/22 04:27 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Same here; I had CalTrac perches put on my Strange S-60 when it was built simply because they're stronger than anything OEM-like.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Spring perches - which ones? [Re: Brad_Haak] #3011629
02/02/22 05:12 PM
02/02/22 05:12 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Make sure the center hole is right size. Get the cheap one and run a strap over the housing connecting the end on both sides, a couple 1” beads will hold it.
