Hotchkis upper control arms
#3011372
02/01/22 10:43 PM
02/01/22 10:43 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
I'm looking into getting a set of the Hotchkis adjustable upper control arms for my cuda. Has anybody noticed a notable difference after installing them? I do like the extra adjustability that's built in, but I'm worried about the longevity of the rod ends on a street car. I'm also not impressed that they come with cheap Taiwan ball joints installed, especially given how much they charge.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Hotchkis upper control arms
[Re: 73cuda340]
#3011490
02/02/22 10:57 AM
02/02/22 10:57 AM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
WOW! Over $1,000! But at least you don't have to remove them to adjust them anymore. I just shorten the rear arms of the stock ones by 1/4" and with the offset bushings have adjustment range to spare. Since I am not much of a welder, a local machine shop will cut them down and weld them back for less than $100. Done quite a few like that over the years.
Master, again and still
[Re: burdar]
#3011509
02/02/22 11:30 AM
02/02/22 11:30 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I have the older Hotchkis arms on my 68 Charger, they correct some geometry issues that the other brands dont, have about 2k miles on them, so far so good, they correct what they call Caster gain, car drives great .
[Re: 68rrunner]
#3012245
02/04/22 07:49 PM
02/04/22 07:49 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Moog sucks now. They used to be about all I would use. But not anymore. They are just more overseas crap, only more expensive. ProForged is what I use now, if at all possible.
[Re: 68rrunner]
#3012710
02/06/22 11:50 AM
02/06/22 11:50 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
The change to Proforged Ball joints was because of the fall off in quality in Moog. They are far superior. Trend analysis found that the Moogs were failing at a ridiculous rate, causing failures and warranty issues. The Hotchkis piece costs as mush as it does because they are made in America. and you're getting the best and most tested factory replacement suspension components on the market. Period. I literally experienced the issue of Moog's "fall off" in quality first hand. The picture is how it came to me in new in the box. This is after the first set wore to sloppiness in less than one oil change/service period.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: tahoechallenge]
#3013026
02/07/22 01:30 PM
02/07/22 01:30 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
I've been using them on my Challenger for about nine years. It was a marked improvement over the factory arms with offset bushings. As far as longevity is concerned I have no issues. I do spray the heim joints about once a month with Triflow. They get squeaky if I don't. For those inclined to get even more longevity out of them, they sell a heim boot kit that I use on all of mine. Pack them with grease and no issues, and no lube service.
