Hotchkis upper control arms #3011372
02/01/22 10:43 PM
02/01/22 10:43 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'm looking into getting a set of the Hotchkis adjustable upper control arms for my cuda. Has anybody noticed a notable difference after installing them? I do like the extra adjustability that's built in, but I'm worried about the longevity of the rod ends on a street car. I'm also not impressed that they come with cheap Taiwan ball joints installed, especially given how much they charge.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Hotchkis upper control arms [Re: 73cuda340] #3011490
02/02/22 10:57 AM
02/02/22 10:57 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
WOW! Over $1,000! But at least you don't have to remove them to adjust them anymore.
I just shorten the rear arms of the stock ones by 1/4" and with the offset bushings have adjustment range to spare. Since I am not much of a welder, a local machine shop will cut them down and weld them back for less than $100. Done quite a few like that over the years. twocents
Master, again and still
Re: Hotchkis upper control arms [Re: DaveRS23] #3011497
02/02/22 11:12 AM
02/02/22 11:12 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've got SPC arms for my Dart. They were on sale on Amazon super cheap so I grabbed them. Way cheaper then these are listed at.
https://eliteracefab.com/products/s...YNEi85SB5sR6dC4EYcwC-fDOCs0aAiUpEALw_wcB
Re: Hotchkis upper control arms [Re: burdar] #3011509
02/02/22 11:30 AM
02/02/22 11:30 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I have the older Hotchkis arms on my 68 Charger, they correct some geometry issues that the other brands dont, have about 2k miles on them, so far so good, they correct what they call Caster gain, car drives great .
Re: Hotchkis upper control arms [Re: CSK] #3011798
02/03/22 08:02 AM
02/03/22 08:02 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have the older Hotchkis UCA also but bought the whole kit shorty after they came out.
I think I paid $1600 for the kit through Summit.
Car doesn't get driven much so don't know about durability,
Re: Hotchkis upper control arms [Re: RTSE4ME] #3012142
02/04/22 01:23 PM
02/04/22 01:23 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
The change to Proforged Ball joints was because of the fall off in quality in Moog. They are far superior. Trend analysis found that the Moogs were failing at a ridiculous rate, causing failures and warranty issues.
The Hotchkis piece costs as mush as it does because they are made in America. and you're getting the best and most tested factory replacement suspension components on the market. Period.
Re: Hotchkis upper control arms [Re: 68rrunner] #3012245
02/04/22 07:49 PM
02/04/22 07:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Moog sucks now. They used to be about all I would use. But not anymore. They are just more overseas crap, only more expensive. ProForged is what I use now, if at all possible.
Re: Hotchkis upper control arms [Re: 68rrunner] #3012710
02/06/22 11:50 AM
02/06/22 11:50 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I literally experienced the issue of Moog's "fall off" in quality first hand. The picture is how it came to me in new in the box. This is after the first set wore to sloppiness in less than one oil change/service period.
Re: Hotchkis upper control arms [Re: jbc426] #3012754
02/06/22 02:43 PM
02/06/22 02:43 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
I've been using them on my Challenger for about nine years. It was a marked improvement over the factory arms with offset bushings. As far as longevity is concerned I have no issues. I do spray the heim joints about once a month with Triflow. They get squeaky if I don't.
Re: Hotchkis upper control arms [Re: tahoechallenge] #3013026
02/07/22 01:30 PM
02/07/22 01:30 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
For those inclined to get even more longevity out of them, they sell a heim boot kit that I use on all of mine. Pack them with grease and no issues, and no lube service.
