By pass fuel regulator #3010057
01/28/22 05:41 PM
01/28/22 05:41 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Truck has an in tank fuel pump with the TBI carb. Thinking of doing a TQ instead, what regulator will allow excess fuel back to tank using stock return line?
Re: By pass fuel regulator [Re: cudaman1969] #3010193
01/29/22 09:53 AM
01/29/22 09:53 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
My 1988 is like that, stock fuel pump, holley carb. I used two standard holley regs I'll get a pic for you. It's a little unconventional but it works, been on there 20 years. runs at 5.5 psi
Re: By pass fuel regulator [Re: B1MAXX] #3010203
01/29/22 10:40 AM
01/29/22 10:40 AM
okla.
sam64 Offline
sam64  Offline
okla.
Holley 12-880 comes with 2 springs,1 for low pressure and 1 for high pressure. low is 4 psi and up and high is up to 65 psi. One reg for Carb or Efi just change spring.
Re: By pass fuel regulator [Re: B1MAXX] #3010205
01/29/22 10:50 AM
01/29/22 10:50 AM
fredericksburg,va
fredericksburg,va
Re: By pass fuel regulator [Re: sam64] #3010206
01/29/22 10:51 AM
01/29/22 10:51 AM
fredericksburg,va
fredericksburg,va
Will it send excess fuel back to tank? Don’t want a dead head.
Re: By pass fuel regulator [Re: cudaman1969] #3010235
01/29/22 12:48 PM
01/29/22 12:48 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
yes
Re: By pass fuel regulator [Re: B1MAXX] #3010344
01/29/22 06:05 PM
01/29/22 06:05 PM
fredericksburg,va
fredericksburg,va
Cool
Re: By pass fuel regulator [Re: cudaman1969] #3010361
01/29/22 06:36 PM
01/29/22 06:36 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I was working in the shop today walking past the truck. Time and time again I am thinking I removed the ball from the first reg. I'll try and take a peek tomorrow.
Re: By pass fuel regulator [Re: B1MAXX] #3010414
01/29/22 10:58 PM
01/29/22 10:58 PM
fredericksburg,va
fredericksburg,va
I had the same thought visualizing how it would work with that check ball.
Re: By pass fuel regulator [Re: cudaman1969] #3010556
01/30/22 02:49 PM
01/30/22 02:49 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
No need to remove.I just have the adjusting set screw run all the way down. Lock nut removed, and the top of the adjusting set screw down in aprox 2 threads from flush. Bringing back some memories now after looking. up I did that in probably 2003/4.
Re: By pass fuel regulator [Re: B1MAXX] #3010792
01/31/22 11:56 AM
01/31/22 11:56 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Re: By pass fuel regulator [Re: Cuda340] #3010816
01/31/22 12:59 PM
01/31/22 12:59 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Nice, but I was to cheap for that. The holleys were like 20 bucks then, and to be honest they were probably just laying around. But I am sure that is nice.
Re: By pass fuel regulator [Re: B1MAXX] #3010871
01/31/22 04:20 PM
01/31/22 04:20 PM
fredericksburg,va
fredericksburg,va
Guess I should ask if there any problems to changing over to the TQ from TBI? Will there be a problem starting, running, electronics, gauges working?
Re: By pass fuel regulator [Re: cudaman1969] #3010914
01/31/22 06:15 PM
01/31/22 06:15 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
You,ll have to wire in a electronic dist. set up, and a voltage reg.. Then disconnect the computer. Evert thing else works as usual on my 1988.
