By pass fuel regulator
#3010057
01/28/22 05:41 PM
01/28/22 05:41 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
Truck has an in tank fuel pump with the TBI carb. Thinking of doing a TQ instead, what regulator will allow excess fuel back to tank using stock return line?
Re: By pass fuel regulator
[Re: B1MAXX]
#3010203
01/29/22 10:40 AM
01/29/22 10:40 AM
Posts: 1,285 okla.
sam64
okla.
Holley 12-880 comes with 2 springs,1 for low pressure and 1 for high pressure. low is 4 psi and up and high is up to 65 psi. One reg for Carb or Efi just change spring.
[Re: B1MAXX]
#3010871
01/31/22 04:20 PM
01/31/22 04:20 PM
cudaman1969
fredericksburg,va
Guess I should ask if there any problems to changing over to the TQ from TBI? Will there be a problem starting, running, electronics, gauges working?
[Re: cudaman1969]
#3010914
01/31/22 06:15 PM
01/31/22 06:15 PM
Posts: 1,993 Apollo, PA.
B1MAXX
Apollo, PA.
You,ll have to wire in a electronic dist. set up, and a voltage reg.. Then disconnect the computer. Evert thing else works as usual on my 1988.
