restorick undercoating #3008813
01/25/22 12:31 PM
01/25/22 12:31 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I was researching undercoating options last week and was comparing RestoRick's undercoating with 3m body shutz. I didn't complete the order form on RestoRick's website but I recieved an invoice anyway. laugh2 Looks like I'll order it from him...it's less expensive then the 3m stuff anyway.
What I was curious about is how you go about spraying it. The 3m body shutz comes in 1 quart containers that screw on to the applicator gun. RestoRick's stuff comes in a gallon container. Does the shutz gun screw to the gallon can or do you have to transfer it to another container to spray it?
I saw this gun listed in an old Moparts thread. This is what I'll probably buy to spray it.
https://www.amazon.com/gp/product/B003D3N7W4/ref=pd_lpo_sbs_dp_ss_1
Re: restorick undercoating [Re: burdar] #3008894
01/25/22 04:06 PM
01/25/22 04:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I used an undercoat gun like you're looking at.
IIRC - it was 10 years ago - I think I transferred from the gallon can to the gun's can.
You might also be able to use a hose from the gallon to the gun.
Rick's stuff was better than anything else I tried, but getting the factory-looking thickness & texture seemed to require a lot of material and a couple applications.
Messy as hell, as all that stuff is; mask or cover everything around the area you're working on, even several feet away.
Re: restorick undercoating [Re: topside] #3008956
01/25/22 06:58 PM
01/25/22 06:58 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Transfer Resto Ricks undercoating to the smaller gun reservoir. I then drill out the gun nozzle to a larger diameter. Then to get the build up like the factory I shoot a heavy coat and then let it dry over night or so then come back and do it again. If you keep building it up on the first pass it will flow out as it cures and you won't get the build up. Also a minimum of 4 beers are needed to get into the factory worker's state of mind.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: restorick undercoating [Re: MOPARMIKE69] #3009069
01/26/22 02:15 AM
01/26/22 02:15 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ That makes sense on a couple levels ! laugh2
Re: restorick undercoating [Re: topside] #3009139
01/26/22 11:23 AM
01/26/22 11:23 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
The gun listed in the link doesn't show an extra reservoir. That's why I was confused. So it looks like I'll have to come up with some sort of reservoir to pour the undercoating in. I do have one of those cheap non-gravity paint guns that's never been used. Maybe that reservoir will work?
Re: restorick undercoating [Re: burdar] #3009245
01/26/22 02:59 PM
01/26/22 02:59 PM
South Dakota
hotairballoonpilot Offline
South Dakota
most auto body supply stores should be able to sell you a new empty can. I have bought them from my paint jobber ABS here in Sioux falls SD absdelivers.com
corey
Contact Me about AMD Prices
Re: restorick undercoating [Re: hotairballoonpilot] #3009353
01/26/22 07:10 PM
01/26/22 07:10 PM
Mass
charge70 Offline
charge70  Offline
Mass
Just purchase a quart of the 3m undercoat,use it as a base and now you have a container to spray resto Ricks stuff.Thats what I do
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: restorick undercoating [Re: MOPARMIKE69] #3009388
01/26/22 08:35 PM
01/26/22 08:35 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Lots of truth to this. There is a reason most painters, including myself, drink or smoke weed.
Re: restorick undercoating [Re: mgoblue9798] #3009578
01/27/22 01:20 PM
01/27/22 01:20 PM
moparx Offline
moparx  Offline
waaay back in the mid 70's, a buddy of mine and i "started" the trend of painting EVERYTHING body color.
when i would get a car in at my junkyard that was good enough to fix and flip, i would contact my buddy, and he would round up all his leftover paint from his body shop. mix it all up until we got the neat-o color we wanted, then spray away after masking the windows and lights. no chrome for us ! laugh2
each car we did that way sold FAST !
i don't know if it was the colors we came up with, or the price we put on the car. we also included a pint or so [or what ever was left of the "custom" mix] for touch up. good luck matching up the color. biggrin
at least we take credit for "giving" the manufactures "our" idea.
beer
Re: restorick undercoating [Re: moparx] #3009627
01/27/22 03:12 PM
01/27/22 03:12 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I believe Eastwood sells the gun/reservoir combination. I like the idea mentioned about hogging out the nozzle. I was a little disappointed with the results I got but I also only did one car so there wasn't much practice or history to go by.
Re: restorick undercoating [Re: LimeliteAero] #3009648
01/27/22 03:56 PM
01/27/22 03:56 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Quote
Any idea on the size to increase it to?
Re: restorick undercoating [Re: MOPARMIKE69] #3012367
02/05/22 06:39 AM
02/05/22 06:39 AM
North Carolina
dge330 Offline
dge330  Offline
North Carolina
yep sounds about right . the last part is the most important one .
Re: restorick undercoating [Re: burdar] #3012399
02/05/22 10:24 AM
02/05/22 10:24 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Sorta off topic, but when RestoRicks product dries, is it tacky or does it dry hard and solid?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: restorick undercoating [Re: A39Coronet] #3012437
02/05/22 12:35 PM
02/05/22 12:35 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
It dries hard and solid..
On a related topic, Undercoating would have been done after fuel line and brake lines were installed, but before the drivetrain, correct?
I’ve had undercoating on the fuel and brake lines, on the gas tank and exhaust shields, upstop bumpers for the axle and is on the wiring for the front side marker lights, but it is not on the drivetrain components or the K frame.
Is that accurate?
Re: restorick undercoating [Re: RP's R/T's] #3012498
02/05/22 04:23 PM
02/05/22 04:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup - seems to have been done before the "body drop" onto the drivetrain & K.
Notice the masking @ ft suspension attachment areas, they only have primer & overspray there.
