Lifted 2014 Ram axle shafts
#3008873
01/25/22 02:54 PM
01/25/22 02:54 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
Seems lifted Rams eat axle shafts pretty quick Anybody ran into this issue, do they make CV shafts with longer travel
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Lifted 2014 Ram axle shafts
[Re: J_BODY]
#3009378
01/26/22 08:00 PM
01/26/22 08:00 PM
B3422W5
Portage,michigan
I’ve only noted the broken upper ball joints on the “cheap” kits that do not provide a revised steering knuckle that corrects the angle. Can’t say I’ve ever seen an axle issue (discussion pertains to the 1500 pickup) and I’m in the desert SW where all the cool kids gotta lift! Shop that does all our service work( last 12 years) says he sees stripped mainly passenger side axle shafts on lifted Rams all the time. This one has a pro comp lift on it. Probably stay away from buying lifted stuff in the future, but this truck is ultra sweet. Very sharp. Its sold, just waiting to get it back from service.
