Who has broken a cast 440 crank?
#3007271
01/20/22 04:20 PM
01/20/22 04:20 PM
Posts: 1,335 Johnstown
69dart
Johnstown
I have a 78 440 in the shop I've been debating building.
I'm debating rather to buy a 493 stoker kit with everything or just throw some pistons and rods at it and go.
The pistons and rods were wasted from the oem build. Looked like someone ran the old school Pennzoil which sludged all the way up until it blocked the pickup, killed a lifter, and smoked the bearings.
Several of the rods and rod bearings were purple/blue with hot spots but the crank itself looks like new.
This would probably be an old school .550-.590 cam, 11.5:1 , Edelbrock or 440 source head type build. Something to maybe run 10.90's in a bracket car.
I've always heard that cast cranks are junk. but who has really broken one and how.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4 68 Dart 340
Re: Who has broken a cast 440 crank?
[Re: AndyF]
#3007403
01/20/22 10:04 PM
01/20/22 10:04 PM
69dart
Johnstown
I don't know what oil they used but it was cooked. We scraped inches of paraffin like crud out of that oil pan. It was knarley. I hoped to build a roadkill motor for a shop truck but it was too wasted. The rods and pistons went with the garbage yesterday.
Andy - I think I bought a 3.89 stroke 413 crank from you years ago. That engine is still ripping 10's in my old dart 20 years later.
Hmm... I might throw some lighter rods and pistons at it and make a nice street strip engine.
[Re: jwb123]
#3007539
01/21/22 11:19 AM
01/21/22 11:19 AM
Posts: 6,164 fredericksburg,va
cudaman1969
fredericksburg,va
Police engines in late 70s had special cast cranks, got one, but my 74 cast crank engine was running 7.70s in my 64 Plym for a year or more before I changed to the steel crank engine. The 74 engine is now going in my Lil Red, maybe 15,000 miles on it. 5500 and both are done up top so that helps a lot, anything will break but I doubt you’ll have a problem btw mopar stocker racers search out for the cast cranks to run in their engines, lighter. 340s (use 318), 383s, 400s and 440s
[Re: BigBlockGTS]
#3007576
01/21/22 12:59 PM
01/21/22 12:59 PM
69dart
Johnstown
I checked here, moparchat and big block a bodies but have not seen anybody say they had actually broken one.
Seems like they may have been highly underated.
I know my buddy cracked an eagle crank after about 2,000 runs...lol. It really didnt tear anything up as he caught it during a refresh and just noticed some bearing worse than normal.
Thank for the replies.
It gives me some food for thought during this long winter.
[Re: 69dart]
#3007585
01/21/22 01:32 PM
01/21/22 01:32 PM
Posts: 17,102 S.E. Michigan
ZIPPY
S.E. Michigan
In a basic 440 that I am planning to have fully machined, start from scratch and "build" (not just re-ring a stock cast crank engine), I'd rather go with a reworked stock forged crank if I can find a good one at reasonable cost. Not because the cast crank will break (it won't) but because "built/fully machined" means it will be balanced too. Personally I feel like I am cheating myself if we get all the components weight matched including the rods end for end, and then kind of wimp out at the end of the process by hanging a bunch of weight off the ends of the crankshaft because it's too light. It's more "ease of internal balance + easy parts interchangeability that follows" rather than any concerns the cast crank is going to break. However even if we're not machining much of anything, and we're not balancing anything either, we can still have some fun with a good old 440 regardless of what crankshaft is in it. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1235800/1.html
Rich H.
[Re: AndyF]
#3007638
01/21/22 04:47 PM
01/21/22 04:47 PM
Posts: 3,677 usa
lewtot184
usa
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was  .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me.
[Re: lewtot184]
#3007639
01/21/22 05:03 PM
01/21/22 05:03 PM
Posts: 3,866 Wichita
GY3
Wichita
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was  .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me. I've weighed both as well. 73 lbs. as I recall regardless of whether they are cast or forged.
[Re: GY3]
#3007671
01/21/22 06:23 PM
01/21/22 06:23 PM
Posts: 3,677 usa
lewtot184
usa
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was  .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me. I've weighed both as well. 73 lbs. as I recall regardless of whether they are cast or forged. that sounds about right to me. i didn't think they were that heavy but seen no difference in weight.
[Re: GY3]
#3007695
01/21/22 07:50 PM
01/21/22 07:50 PM
Posts: 160 PA
Scully
PA
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was  .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me. I've weighed both as well. 73 lbs. as I recall regardless of whether they are cast or forged. I weighed a 383 steel, 400 cast, 440 steel and 440 cast, all 4 were 76 lbs.
[Re: Scully]
#3007704
01/21/22 08:17 PM
01/21/22 08:17 PM
Posts: 11,468 Kalispell Mt.
HotRodDave
Kalispell Mt.
If this is true then it begs a couple questions...
1. Why do the SS racers run them?
2. Why did they require weight added on both ends of the crank to get them to balance with the same rods and pistons as a forged crank?
Maybe it's only 1/2 pound and the less weight is worth it like a thousand other tiny seemingly insignificant things the SS racers do.
