Re: Who has broken a cast 440 crank?
[Re: jwb123]
#3007539
01/21/22 11:19 AM
01/21/22 11:19 AM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Police engines in late 70s had special cast cranks, got one, but my 74 cast crank engine was running 7.70s in my 64 Plym for a year or more before I changed to the steel crank engine. The 74 engine is now going in my Lil Red, maybe 15,000 miles on it. 5500 and both are done up top so that helps a lot, anything will break but I doubt you’ll have a problem btw mopar stocker racers search out for the cast cranks to run in their engines, lighter. 340s (use 318), 383s, 400s and 440s
[Re: 69dart]
#3007585
01/21/22 01:32 PM
01/21/22 01:32 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
In a basic 440 that I am planning to have fully machined, start from scratch and "build" (not just re-ring a stock cast crank engine), I'd rather go with a reworked stock forged crank if I can find a good one at reasonable cost. Not because the cast crank will break (it won't) but because "built/fully machined" means it will be balanced too. Personally I feel like I am cheating myself if we get all the components weight matched including the rods end for end, and then kind of wimp out at the end of the process by hanging a bunch of weight off the ends of the crankshaft because it's too light. It's more "ease of internal balance + easy parts interchangeability that follows" rather than any concerns the cast crank is going to break. However even if we're not machining much of anything, and we're not balancing anything either, we can still have some fun with a good old 440 regardless of what crankshaft is in it. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1235800/1.html
Rich H.
Esse Quam Videri
[Re: AndyF]
#3007638
01/21/22 04:47 PM
01/21/22 04:47 PM
Posts: 3,916 usa
lewtot184
usa
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me.
[Re: lewtot184]
#3007639
01/21/22 05:03 PM
01/21/22 05:03 PM
Posts: 4,669 Wichita
GY3
Wichita
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me. I've weighed both as well. 73 lbs. as I recall regardless of whether they are cast or forged.
[Re: GY3]
#3007671
01/21/22 06:23 PM
01/21/22 06:23 PM
Posts: 3,916 usa
lewtot184
usa
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me. I've weighed both as well. 73 lbs. as I recall regardless of whether they are cast or forged. that sounds about right to me. i didn't think they were that heavy but seen no difference in weight.
[Re: GY3]
#3007695
01/21/22 07:50 PM
01/21/22 07:50 PM
Posts: 200 PA
Scully
PA
i had a steel 440 crank and '73 cast 440 crank.. put them both on the bathroom scales and they weighed the same. i know it's not precise weighing but it was what it was .i wouldn't be afraid of a cast crank at a reasonable power level. reasonable is maybe 500hp to me. I've weighed both as well. 73 lbs. as I recall regardless of whether they are cast or forged. I weighed a 383 steel, 400 cast, 440 steel and 440 cast, all 4 were 76 lbs.
