Anyone knowledgeable about ROKUs??
#3007437
01/21/22 12:18 AM
01/21/22 12:18 AM
Posts: 16,843 Between Houston & Galveston TX
SattyNoCar
Having a connection issue with my Roku, seems to be a (now) common problem with no simple solution. I spent w-a-y too much time on the phone with xfinity and Roku today and got no where with either, so I thought I'd throw this out to you fine people before I go at them again. Internet/wifi is provided by xfinity. I have 6 other items in my apt that are connected to the wifi with no issues. As of 7:30 PM Wednesday night, Roku will no longer connect to my Wifi. I was right in the middle of watching something when POOF gone! ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) It's done this before but I've always been able to reconnect. ![work work](/ubbthreads/images/graemlins/custom/work.gif) Weird thing (to me) was that the Roku wouldn't even find my WIFI when I'd run a scan. I'm in an apt, it would find everyone around me, but not mine. ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) Went and bought a new one (express 4K+), and this new one finds my WiFi but still won't connect. ![flame flame](/ubbthreads/images/graemlins/custom/flame.gif) Xfinity blames Roku, Roku blames Xfinity, you know the drill. Tried different settings, nothing makes a difference. Any suggestions? (as an aside, been using Roku for almost 10 yrs and this is the first major issue I've had with them)
John
Re: Anyone knowledgeable about ROKUs??
[Re: SattyNoCar]
#3007444
01/21/22 01:02 AM
01/21/22 01:02 AM
Posts: 4,961 WI
Dcuda69
WI
Disconnect power to everything. Wait a few minutes....reboot the modem. Reboot your router. Confirm you have internet connection. Your Roku will likely reconnect and work as designed. All of those devices have an IP address that will re-establish on a reboot
[Re: Dcuda69]
#3007450
01/21/22 01:22 AM
01/21/22 01:22 AM
Posts: 16,546 On the run…
BloFish
On the run…
Disconnect power to everything. Wait a few minutes....reboot the modem. Reboot your router. Confirm you have internet connection. Your Roku will likely reconnect and work as designed. All of those devices have an IP address that will re-establish on a reboot ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) that’s what I have to do from time to time.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3007478
01/21/22 06:56 AM
01/21/22 06:56 AM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Disconnect power to everything. Wait a few minutes....reboot the modem. Reboot your router. Confirm you have internet connection. Your Roku will likely reconnect and work as designed. All of those devices have an IP address that will re-establish on a reboot ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) that’s what I have to do from time to time. Yes YES YES. This is a typical issue with streaming TV tech. Disconnect power for 10-20 seconds from everything but ESPECIALLY your modem. I have 3 Roku devices in my home and occasionally one- just one will no longer connect.....until I unplug my modem for a slow count to ten then plug back in.
Keep old mopars alive.
[Re: 2boltmain]
#3007516
01/21/22 10:30 AM
01/21/22 10:30 AM
SattyNoCar
It might have saved time had I mentioned I tried disconnecting power NUMEROUS times to no avail. (sorry guys ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) ). Matter of fact, I unplugged everything before I went to bed last night and plugged everything in this morning, no different. I've tried everything xfinity suggested, I've tried everything roku suggested, and nothing. I'm a little pissed right now. Thanks guys. Anybody wanna buy two rokus? This is what I keep getting.........
John
[Re: SattyNoCar]
#3007518
01/21/22 10:35 AM
01/21/22 10:35 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
John, have you tried pressing the connect button on your router when trying to connect? Sometimes it's the only way I can get my HP printer hooked up.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Andrewh]
#3007542
01/21/22 11:23 AM
01/21/22 11:23 AM
SattyNoCar
Well, I got it working, but I'm still not convinced its fixed because I don't understand why what I did made a difference. I updated my password for xfinity. That's all I did. I changed it on xfinity, waited a moment, then tried Roku again and this time it worked. ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) Yes, I was entering my old password correctly Security issue with old password? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I dunno. Thanks for the help guys. And to answer Andrew, I was told the Roku works off of the 2.4ghz wifi, and the wifi mode needs to be set to 802.11 b,g,n . Mine was originally at 802.11 g.n . This was one of the first things I tried at the recommendation of Roku. It is still set at 'b.g.n' , I haven't changed it back. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
John
[Re: Andrewh]
#3007577
01/21/22 01:02 PM
01/21/22 01:02 PM
SattyNoCar
Thank you Andrew, the b.g.n. makes sense now. As for the password........ ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) While troubleshooting this problem, I was accessing my xfinity on my phone. This morning I pulled up my xfinity account on my PC and got a warning from windows about needing to change my password, which I did. Like you said, it shouldn't affect logging into wifi, but since nothing else worked, I tried this new password on the roku and it seems to have worked. Seems to. ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif)
John
