Where can I find flexplate to crank bolts? #3007248
01/20/22 03:37 PM
01/20/22 03:37 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I have a Rb engine with a aftermarket stroker crank and have been having a tough time finding flex plate bolts. Summit and Jegs won’t have them till April and my local engine builders don’t have them either. Bolt has to have a thin head to clear the torque converter.
Mancini and rosewood don’t have them either.
May have to look at McMaster carr or fastenal.
And places you guys know about?
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007254
01/20/22 03:51 PM
01/20/22 03:51 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
6 bolt flange, 7/16" thread? ARP 200-2903, Summit show in stock shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007262
01/20/22 04:06 PM
01/20/22 04:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm going to assume 8 bolts, 1/2"-20. ARP 200-2905
There are a few around. ebay, some smaller shops and sellers. transmission shops, etc.
Re: Where can I find flexplate to crank bolts? [Re: CMcAllister] #3007268
01/20/22 04:15 PM
01/20/22 04:15 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I have the six bolt but not the 8 (they are different size) I have the Converter bolts as well/
Todd
Re: Where can I find flexplate to crank bolts? [Re: sasquatch] #3007279
01/20/22 04:41 PM
01/20/22 04:41 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I need the 8 bolt. I’ll check around some more. Thanks for the part no.
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007285
01/20/22 04:54 PM
01/20/22 04:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Pretty sure 440source had them last time I was on their website.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Where can I find flexplate to crank bolts? [Re: pittsburghracer] #3007291
01/20/22 05:18 PM
01/20/22 05:18 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Several sets on ebay. Coan shows them. Not a lot around. You find them, you better grab them. Prolly next month before the big guys have them.
I didn't look for any cheapies.
Re: Where can I find flexplate to crank bolts? [Re: CMcAllister] #3007295
01/20/22 05:24 PM
01/20/22 05:24 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Coan doesn’t have them. 440 source doesn’t either,
I can’t find them on eBay.
Could you send me a link?
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007344
01/20/22 07:00 PM
01/20/22 07:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
PM sent.
Re: Where can I find flexplate to crank bolts? [Re: CMcAllister] #3007363
01/20/22 08:17 PM
01/20/22 08:17 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007372
01/20/22 08:46 PM
01/20/22 08:46 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
As a last resort, you may consider doing what I do; get the right length Grade 8 bolts from the hardware store. Chuck them up in a drill and grind the head down on a bench grinder. Doesn't take too long and is a darned sight cheaper than the packaged flex plate bolts. Works for the converter bolts, too. twocents
Master, again and still
Re: Where can I find flexplate to crank bolts? [Re: B1duster] #3007489
01/21/22 08:45 AM
01/21/22 08:45 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I hope its not because they are waiting for a shipment from China. work ARP that is.....
Re: Where can I find flexplate to crank bolts? [Re: B1MAXX] #3007543
01/21/22 11:25 AM
01/21/22 11:25 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Where can I find flexplate to crank bolts? [Re: bigdad] #3007560
01/21/22 12:07 PM
01/21/22 12:07 PM
Spokane Wa
slick526 Offline
slick526  Offline
Spokane Wa
I had the same problem last June. ARP said they were 12 weeks out. If they still don't have them, yes I would wonder if they get them from China????
I ended up taking grade 8 bolts and have them cut down on a lathe. Getting parts these days is a joke!
Qwik Brick
Re: Where can I find flexplate to crank bolts? [Re: slick526] #3007568
01/21/22 12:38 PM
01/21/22 12:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Same problem in 2020, no arp head bolts for Gen 2 hemi with Edelbrock heads for the forseeable future,
and not available on the shelf anywhere. I'd really rather have rather used bolts but studs were a few dollars less for
no particular reason and were available sooner.
I'm pretty sure most companies are plenty busy making LS stuff just as fast as they can sell it.
Rich H.
Esse Quam Videri
Re: Where can I find flexplate to crank bolts? [Re: ZIPPY] #3007571
01/21/22 12:44 PM
01/21/22 12:44 PM
Apollo, PA.
Apollo, PA.
You cold make every fastener for an ls by the millions in 12 weeks...something else wrong here.
Re: Where can I find flexplate to crank bolts? [Re: B1MAXX] #3007607
01/21/22 03:19 PM
01/21/22 03:19 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Found a set at a small speed shop. But our next move was to chuck some bolts up in a lathe.
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007610
01/21/22 03:22 PM
01/21/22 03:22 PM
moparx Offline
moparx  Offline
8 bolt cranks are 1/2-20 thread, and 6 bolt cranks are 7/16-20 thread, correct ?
beer
Re: Where can I find flexplate to crank bolts? [Re: moparx] #3007693
01/21/22 07:46 PM
01/21/22 07:46 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Yes
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3007804
01/22/22 10:55 AM
01/22/22 10:55 AM
NY
B1duster Offline
B1duster  Offline
NY
If you want to make your own, you can have these if you pay postage
