UPDATING '65 STEERING COLUMN FOR SAFETY #3006072
01/16/22 10:22 PM
01/16/22 10:22 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
WHAT'S A QUICK AND EASY METHOD TO UPDATING THE FACTORY STEERING COLUMN FROM 1965A BODY?
Re: UPDATING '65 STEERING COLUMN FOR SAFETY [Re: A/MP] #3006092
01/16/22 11:36 PM
01/16/22 11:36 PM
Updating what part for safety? confused
I have swap columns in several early, pre 1970, Mopars with later ones work scope
Re: UPDATING '65 STEERING COLUMN FOR SAFETY [Re: Cab_Burge] #3006139
01/17/22 09:50 AM
01/17/22 09:50 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think adding a collapsible shaft would make it a little safer. twocents
Re: UPDATING '65 STEERING COLUMN FOR SAFETY [Re: A/MP] #3006191
01/17/22 01:22 PM
01/17/22 01:22 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
. Depending on how much exposed steering shaft exists below the column housing you can cut it off and add a DD slip joint from there to the shaft/box coupler. If not enough is exposed it may be possible to disassemble and install it mid span between the upper and lower support bearings in the column housing. Or find one from a later model as stated by others. If you make a DD slip joint, with the shaft at its installed length install a nylon screw from the outer DD into the inner dd to keep it from moving in and out
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: UPDATING '65 STEERING COLUMN FOR SAFETY [Re: A/MP] #3006193
01/17/22 01:30 PM
01/17/22 01:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I think they started making collapsible columns in 68. Could go that way.
Re: UPDATING '65 STEERING COLUMN FOR SAFETY [Re: rickraw] #3006212
01/17/22 02:39 PM
01/17/22 02:39 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
https://www.speedwaymotors.com/Ididit-3000460018-Steering-Shaft-Collapsible-18-1-2-Inch,376068.html
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: UPDATING '65 STEERING COLUMN FOR SAFETY [Re: bigdad] #3006219
01/17/22 02:50 PM
01/17/22 02:50 PM
moparx Offline
moparx  Offline
Speedway has a bunch of different parts a fellow can use for our preferred brand, but a lot of guys just think of them as a chevy dirt burner supply house, and go directly to Jegs or Summitt.
i have dealt with Speedway quite a few times, both on line and by phone, and have been more than satisfied with that company and their parts. up
beer
