Holley squirter question #3005279
01/14/22 03:15 PM
01/14/22 03:15 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Which is better, straight or tube type and why?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Holley squirter question [Re: 68LAR] #3005400
01/14/22 10:57 PM
01/14/22 10:57 PM
I would try both to see what YOUR motor likes scope twocents
The ones with the nozzles sticking out into the air stream probably make a finer mixture boogie
Re: Holley squirter question [Re: 68LAR] #3005407
01/14/22 11:27 PM
01/14/22 11:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Don't the tube type tend to introduce fuel as air flow increases? The tubes extend into the air stream slightly allowing the air flow to exert pull on the openings. Where as the straight does not.
www.cnc-motorsports.com/aed-5531-holley-accelerator-pump-squirters-tube-type-031-2-per-pk-29892.html
www.speed-talk.com/forum/viewtopic.php?t=54922
Master, again and still
Re: Holley squirter question [Re: DaveRS23] #3005426
01/15/22 01:10 AM
01/15/22 01:10 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
If they were any better than these I think more cabs would be equiped that way. Below are some squirter pullover videos:
https://m.youtube.com/watch?v=OKgYEZCqlbc
https://m.youtube.com/watch?v=Cim0bX5nY-E
Tube dischange style squirters might help as long as they don't cause degrade the flow characteristics of the venturi.
Re: Holley squirter question [Re: DaveRS23] #3005428
01/15/22 01:13 AM
01/15/22 01:13 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
From the cnc motorsports link:
"We recommend Tube squirters when additional top end fuel enrichment is required."
Now I might have to test that theory. Very interesting topic.
Re: Holley squirter question [Re: Jeremiah] #3005523
01/15/22 12:29 PM
01/15/22 12:29 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
From looking at those video's, it looks to me like the straight type is pulling fuel ?
Re: Holley squirter question [Re: Jeremiah] #3005524
01/15/22 12:32 PM
01/15/22 12:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I had a "pullover" issue using the extended-tube-type on the primaries on my SB drag motor.
Replacing them with the flat style cured it.
That was a worked-over 850DP on 368CI W2, FWIW.
Re: Holley squirter question [Re: 68LAR] #3005596
01/15/22 02:54 PM
01/15/22 02:54 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Apparently there are different weight balls and needle valves to help control that, too.
Re: Holley squirter question [Re: DaveRS23] #3005610
01/15/22 03:28 PM
01/15/22 03:28 PM
up grin
Re: Holley squirter question [Re: Cab_Burge] #3005640
01/15/22 04:37 PM
01/15/22 04:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I use the anti siphon ones,
