BJH balancer ? #3005264
01/14/22 02:36 PM
01/14/22 02:36 PM
moparx Offline OP
moparx  Offline OP
i got this BJH balancer [13767 stamped part # ?] with a box of other "stuff", and i need your opinion[s] if it is worth repairing, or just toss in the junk.
the pulley bolt pattern is the early asymmetric pattern.
the keyway is gacked up, which i can re-broach here at home in my shop.
the seal surface is ate up, which i can [i think] repair by either machining it down and making a steel sleeve, or possibly just using a speedy-sleeve. also able to do here.
if i machine it down until all the grooves are gone, then make a stainless sleeve to press on [.0005-.001 press fit], will it need re-balanced then ?
TIA as always, for the WAY smarter than i members here that will help me out. bow
beer
Re: BJH balancer ? [Re: moparx] #3005336
01/14/22 07:45 PM
01/14/22 07:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I wouldn’t spend the time repairing it, not saying u couldn’t but, there could be a possible failure leading to engine destruction. Buy an Ati.
Re: BJH balancer ? [Re: moparx] #3005372
01/14/22 09:52 PM
01/14/22 09:52 PM
AndyF Online content
AndyF  Online Content
Toss it or sell it on CL for $50.
Re: BJH balancer ? [Re: AndyF] #3005392
01/14/22 10:32 PM
01/14/22 10:32 PM
NC
440Jim Offline
440Jim  Offline
NC
My 2-cents twocents
If the elastomer (damping material) can't be replaced/rebuilt, it isn't worth repairing the mechanical wear.
Re: BJH balancer ? [Re: 440Jim] #3005598
01/15/22 03:00 PM
01/15/22 03:00 PM
moparx Offline OP
moparx  Offline OP
thanks to all for steering me in the right direction ! bow
growing up around depression era relatives, i developed a "saving" attitude, then developing a machinist trade and skills, i look at everything as saveable, and go off on a tangent.
probably explains why i have so many projects, and my toys are not running.
i need one of you guys to stop over and whack me upside my head [with that $200.00 hammer, of course ! hammer] to quit looking at saving everything ! laugh2
beer
Re: BJH balancer ? [Re: moparx] #3005620
01/15/22 03:54 PM
01/15/22 03:54 PM
Are you really poor? Is it the middle of a depression? If not then don't save worn out junk. If yes, then save the worn out junk and trade it for food or shoes or bullets.
Re: BJH balancer ? [Re: AndyF] #3005631
01/15/22 04:17 PM
01/15/22 04:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Today we have the throw away kids, fix it, not a dang thing wrong with it. A little time and effort on your part but no biggy. I guess the ones wanting to sell have $150,000 jobs with $1500 in their pocket.
Re: BJH balancer ? [Re: cudaman1969] #3005691
01/15/22 06:21 PM
01/15/22 06:21 PM
Good guess!
Re: BJH balancer ? [Re: moparx] #3005712
01/15/22 07:51 PM
01/15/22 07:51 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
What is that BHJ supposed to fit? It's machined differently than the 2 for BBM w/ internal-balance that I have (a really one old and a new one I picked up a few years ago)... mine don't have round holes, they have oblong "slots". Can you tell if it's an SFI-approved or standard (non-approved) version?
At one point BHJ offered a rebuild service, which I used to freshen up my old one before putting it back in service; not sure if that's still an option. I also know they offer snout sleeves to use for reducing wear on their aluminum-hub models, but no reason why a sleeve can't be used for a steel one w/ the right interference fit. There's probably an OEM damper snout repair kit that uses a sleeve buried in a parts box somewhere in my stash, IIRC.
Not suggesting that any of this is cost effective, only that there may be options to keep it in service.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: BJH balancer ? [Re: Brad_Haak] #3005863
01/16/22 10:54 AM
01/16/22 10:54 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Thats their aluminum hub version, not an el cheapo by any means. It lists for a lot more than an ATI. Goes to show that even if you have a lot of money you still can't recognize an expensive part, unless its shiny. laugh2
Re: BJH balancer ? [Re: B1MAXX] #3005866
01/16/22 10:59 AM
01/16/22 10:59 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
There is nothing wrong with the inside of the snout. Thats what they look like after installation. As long as it has a good press fit going on its good. Then you can brag that you have a more expensive damper than an ATI. up
Re: BJH balancer ? [Re: B1MAXX] #3005869
01/16/22 11:31 AM
01/16/22 11:31 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
^^^ This guy knows. That's a good piece.
Re: BJH balancer ? [Re: Hot 340] #3005870
01/16/22 11:34 AM
01/16/22 11:34 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If throwing away then I’ll send my address and pay shipping.
Re: BJH balancer ? [Re: moparx] #3005944
01/16/22 02:02 PM
01/16/22 02:02 PM
Boise
Moparteacher Offline
Boise
That groove is in need of repair if you ever want to trust the timing light in the future.
A speedy sleeve is simple, cheap and it works. No rebalance needed.
If you can repair the groove then it's a cheap and easy fix.
If your pulley is symmetrical then either elongate a hole, leave the bolt out, or plug a hole and redrill.
You should check the relationship between the timing mark on the outer band and the keyway to confirm the band hasn't slipped. If it has slipped then let it go.
Also confirm a good press fit on the crank snout. If loose then trash.
Re: BJH balancer ? [Re: Moparteacher] #3006068
01/16/22 09:43 PM
01/16/22 09:43 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would never put an aluminum hub damper on anything. Poor choice of materials for that application in my opinion. The damage is proof of that. Only a slight amount of heat would (and it appears has) loosen the press fit, and worn the key slot.
Re: BJH balancer ? [Re: TRENDZ] #3006094
01/16/22 11:37 PM
01/16/22 11:37 PM
iagree I did that ONCE, never again tsk
Re: BJH balancer ? [Re: Cab_Burge] #3006141
01/17/22 09:59 AM
01/17/22 09:59 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
what is the key groove width?
Re: BJH balancer ? [Re: B1MAXX] #3006208
01/17/22 02:02 PM
01/17/22 02:02 PM
moparx Offline OP
moparx  Offline OP
0.185 at the front, 0.202 at the rear.
it's obvious it has been moving around.
i'm considering to cut the keyway to 0.250 if i can find a stepped key.
that is if i decide to do anything with this balancer.
beer
Re: BJH balancer ? [Re: moparx] #3006324
01/17/22 09:08 PM
01/17/22 09:08 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
make the key, you could make it custom to utilize the whole grove., also the redi-sleve is a 25 dollar option on those from new.
I think something was amiss on the original install.
Re: BJH balancer ? [Re: moparx] #3006474
01/18/22 11:51 AM
01/18/22 11:51 AM
an8sec70cuda Offline
Sell it and buy a good one. twocents I had a brand new BHJ once. It slipped the outer ring over an inch around after one trip to the track on a 500 hp engine. Sent it back and had it repaired, but they offered no explanation on the cause of failure and wouldn't return my phone calls.
Been using ATI and Fluidampers ever since.
CHIP
'06 GMC 2500HD LBZ Duramax
