BJH balancer ?
#3005264
01/14/22 02:36 PM
01/14/22 02:36 PM
Posts: 19,342 north of coder
moparx
i got this BJH balancer [13767 stamped part # ?] with a box of other "stuff", and i need your opinion[s] if it is worth repairing, or just toss in the junk. the pulley bolt pattern is the early asymmetric pattern. the keyway is gacked up, which i can re-broach here at home in my shop. the seal surface is ate up, which i can [i think] repair by either machining it down and making a steel sleeve, or possibly just using a speedy-sleeve. also able to do here. if i machine it down until all the grooves are gone, then make a stainless sleeve to press on [.0005-.001 press fit], will it need re-balanced then ? TIA as always, for the WAY smarter than i members here that will help me out.
Re: BJH balancer ?
[Re: 440Jim]
#3005598
01/15/22 03:00 PM
01/15/22 03:00 PM
moparx
thanks to all for steering me in the right direction ! growing up around depression era relatives, i developed a "saving" attitude, then developing a machinist trade and skills, i look at everything as saveable, and go off on a tangent. probably explains why i have so many projects, and my toys are not running. i need one of you guys to stop over and whack me upside my head [with that $200.00 hammer, of course ! ] to quit looking at saving everything !
Re: BJH balancer ?
[Re: moparx]
#3005712
01/15/22 07:51 PM
01/15/22 07:51 PM
Posts: 1,117 Loudoun County, VA
Brad_Haak
Loudoun County, VA
What is that BHJ supposed to fit? It's machined differently than the 2 for BBM w/ internal-balance that I have (a really one old and a new one I picked up a few years ago)... mine don't have round holes, they have oblong "slots". Can you tell if it's an SFI-approved or standard (non-approved) version?
At one point BHJ offered a rebuild service, which I used to freshen up my old one before putting it back in service; not sure if that's still an option. I also know they offer snout sleeves to use for reducing wear on their aluminum-hub models, but no reason why a sleeve can't be used for a steel one w/ the right interference fit. There's probably an OEM damper snout repair kit that uses a sleeve buried in a parts box somewhere in my stash, IIRC.
Not suggesting that any of this is cost effective, only that there may be options to keep it in service.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: BJH balancer ?
[Re: Moparteacher]
#3006068
01/16/22 09:43 PM
01/16/22 09:43 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would never put an aluminum hub damper on anything. Poor choice of materials for that application in my opinion. The damage is proof of that. Only a slight amount of heat would (and it appears has) loosen the press fit, and worn the key slot.
Re: BJH balancer ?
[Re: B1MAXX]
#3006208
01/17/22 02:02 PM
01/17/22 02:02 PM
moparx
what is the key groove width? 0.185 at the front, 0.202 at the rear. it's obvious it has been moving around. i'm considering to cut the keyway to 0.250 if i can find a stepped key. that is if i decide to do anything with this balancer.
Re: BJH balancer ?
[Re: moparx]
#3006324
01/17/22 09:08 PM
01/17/22 09:08 PM
Posts: 1,965 Apollo, PA.
B1MAXX
Apollo, PA.
make the key, you could make it custom to utilize the whole grove., also the redi-sleve is a 25 dollar option on those from new.
I think something was amiss on the original install.
Re: BJH balancer ?
[Re: moparx]
#3006474
01/18/22 11:51 AM
01/18/22 11:51 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Sell it and buy a good one. I had a brand new BHJ once. It slipped the outer ring over an inch around after one trip to the track on a 500 hp engine. Sent it back and had it repaired, but they offered no explanation on the cause of failure and wouldn't return my phone calls. Been using ATI and Fluidampers ever since.
