magnum vs LA parts question #3005092
01/13/22 10:36 PM
01/13/22 10:36 PM
baldwinsville new york
a493demon Offline OP
Is the LA and Magnum timing chain the same ?
Also what B&M flex plate are you using on the magnum with a 727 ?
Thanks , haven't messed with SB stuff in 25 years .
Re: magnum vs LA parts question [Re: a493demon] #3005094
01/13/22 10:44 PM
01/13/22 10:44 PM
Guitar Jones Offline
Magnums have a short snout camshaft because they don't have a fuel pump eccentric. The sprockets and chains can be swapped but the attaching bolt and washer is different, all magnums come with a silent link chain.
As for the flex plate B&M should know, I don't.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: magnum vs LA parts question [Re: Guitar Jones] #3005167
01/14/22 09:17 AM
01/14/22 09:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The Magnum and LA are balanced differently. B&M flex plate for the Magnum is 10242. There is a cam snout adapter to run a mechanical the fuel pump with a Magnum cam and LA front timing cover. You need a 45 degree adapter at the bypass hose to run the LA front cover.
Doug
Re: magnum vs LA parts question [Re: dvw] #3005329
01/14/22 06:59 PM
01/14/22 06:59 PM
thanks
Re: magnum vs LA parts question [Re: dvw] #3005597
01/15/22 02:55 PM
01/15/22 02:55 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Doug
I believe only the 5.9/360 magnum require a specific flexplate.
I also believe the 5.2/318 Magnum is internaly balanced.
Re: magnum vs LA parts question [Re: 1Fast340] #3005862
01/16/22 10:49 AM
01/16/22 10:49 AM
Doug
I have a 360 but that's good to know
