Power window motor rebuild question
#3004903
01/13/22 02:25 PM
01/13/22 02:25 PM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The driver's window in my Cuda has gotten slow to go up and sometimes doesn't quite make it to the top. I need to pull it apart and check the spring and such, but if it's the motor getting weak as I suspect, who can reman it back to working order?
Thanks!
Master, again and still
Re: Power window motor rebuild question
[Re: moparx]
#3004921
01/13/22 02:48 PM
01/13/22 02:48 PM
Posts: 19,529 north of coder
moparx
in fact, rock auto lists the cardone reman for your cuda as #4244, and the same motor is used in the 77 fury. i'm guessing the same motor was used in a bunch of different models and years. don't know if this helps you or not.
[Re: DaveRS23]
#3005025
01/13/22 07:45 PM
01/13/22 07:45 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Rockauto has them? Who knew? I didn't even think to look there. I will pull it down soon and figure out just what is wrong. I might even tackle taking the motor apart as suggested since there is a back-up plan of sorts with Rockauto.
Thanks guys!
[Re: DaveRS23]
#3005140
01/14/22 02:38 AM
01/14/22 02:38 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks! Contact Topher McGinnis 980-329-5938 he rebuilds just about any vintage Mopar electric motor, stellar reputation and quality work.... http://www.headlightmotorman.com/contact-me
[Re: DaveRS23]
#3005172
01/14/22 09:33 AM
01/14/22 09:33 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
More good suggestions. Thank you for them.
[Re: EW1BH27]
#3005497
01/15/22 11:18 AM
01/15/22 11:18 AM
Posts: 1,006 rust belt
Moparite
rust belt
Not to mention the window slides need lube. 50 year old grease with dirt in it acts like dried chewing gum. Try fully cleaning everything and using new grease it will make a big difference.
