Power window motor rebuild question #3004903
01/13/22 02:25 PM
01/13/22 02:25 PM
Benton, IL.
DaveRS23 Offline OP
DaveRS23  Offline OP
Benton, IL.
The driver's window in my Cuda has gotten slow to go up and sometimes doesn't quite make it to the top. I need to pull it apart and check the spring and such, but if it's the motor getting weak as I suspect, who can reman it back to working order?
Thanks!
KOS
Re: Power window motor rebuild question [Re: DaveRS23] #3004909
01/13/22 02:34 PM
01/13/22 02:34 PM
moparx Offline
moparx  Offline
any chance of just swapping it out with another good motor ?
i think those motors are used in a bunch of different applications, not just model specific.
beer
Re: Power window motor rebuild question [Re: moparx] #3004921
01/13/22 02:48 PM
01/13/22 02:48 PM
moparx Offline
moparx  Offline
in fact, rock auto lists the cardone reman for your cuda as #4244, and the same motor is used in the 77 fury.
i'm guessing the same motor was used in a bunch of different models and years.
don't know if this helps you or not.
beer
Re: Power window motor rebuild question [Re: moparx] #3004972
01/13/22 04:38 PM
01/13/22 04:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Generally, a good cleaning and regrease of teh gear assembly does it. Not to mention the window slides need lube.
Re: Power window motor rebuild question [Re: DaveRS23] #3005025
01/13/22 07:45 PM
01/13/22 07:45 PM
Benton, IL.
DaveRS23 Offline OP
DaveRS23  Offline OP
Benton, IL.
Rockauto has them? Who knew? I didn't even think to look there. I will pull it down soon and figure out just what is wrong. I might even tackle taking the motor apart as suggested since there is a back-up plan of sorts with Rockauto.
Thanks guys!
KOS
Re: Power window motor rebuild question [Re: DaveRS23] #3005081
01/13/22 10:15 PM
01/13/22 10:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You might want to verify the voltage and grounds. Or use a couple of decent gauge jumper wires from the battery to the motor. Doing so will expose or confirm the issue is within the door. IE: motor or lubrication etc. beer
Re: Power window motor rebuild question [Re: DaveRS23] #3005140
01/14/22 02:38 AM
01/14/22 02:38 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks!
Contact Topher McGinnis 980-329-5938 he rebuilds just about any vintage Mopar electric motor, stellar reputation and quality work.... http://www.headlightmotorman.com/contact-me
Re: Power window motor rebuild question [Re: DAYCLONA] #3005168
01/14/22 09:19 AM
01/14/22 09:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The later motor fits.
Doug
Re: Power window motor rebuild question [Re: DaveRS23] #3005172
01/14/22 09:33 AM
01/14/22 09:33 AM
Benton, IL.
DaveRS23 Offline OP
DaveRS23  Offline OP
Benton, IL.
More good suggestions. Thank you for them.
KOS
Re: Power window motor rebuild question [Re: DaveRS23] #3005175
01/14/22 09:54 AM
01/14/22 09:54 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
There's not much to them, why not try cleaning & re-greasing it yourself first. I was given one to fix only to find someone scavenged the brushes out of it.
Re: Power window motor rebuild question [Re: EW1BH27] #3005497
01/15/22 11:18 AM
01/15/22 11:18 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
50 year old grease with dirt in it acts like dried chewing gum. Try fully cleaning everything and using new grease it will make a big difference.
