Need 273 air cleaner pie tin for larger air cleaner #3004510
01/12/22 12:03 PM
01/12/22 12:03 PM
Slidell, La.
doctor_mopar Offline OP
Slidell, La.
I am going to use the larger 68 340 air cleaner , and I would prefer to have a pie tin like the Plymouth 340 in red, but with a 273 callout . I see the decal for the 273 air cleaner , but I don’t think it would layout right on the larger air cleaner , and I would prefer it on a pie tin . Any ideas who might make one, or have them ? I am thinking I may need to modify the callout on a 340 tin . Thanks !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: doctor_mopar] #3004515
01/12/22 12:30 PM
01/12/22 12:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You may have to buy the decal and cut the individual letters out and place them on the pie tin your plan on using. If that does not work based on size and spacing you can pay a sign shop to scan the numbers/letters off a new decal and make new ones in a larger size if that is what it takes.
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: doctor_mopar] #3004546
01/12/22 01:50 PM
01/12/22 01:50 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
My first step would be to copy several good images to your phone, and take that to a couple of your local graphics shops and talk to them. You might be surprised at what some can do.
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: Fat_Mike] #3004559
01/12/22 02:10 PM
01/12/22 02:10 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I did just that (a "426" callout on a 440) for a project a few years ago.
Local graphics place figured out a cut line to get the flat applique to work with the tapered center of the lid.
It could go over a pie tin or the lid itself.
Had to look closely to see the seam once I installed it.
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: doctor_mopar] #3004673
01/12/22 06:22 PM
01/12/22 06:22 PM
Slidell, La.
Slidell, La.
Thank You for the Suggestions ! Gives me some places to start !
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: doctor_mopar] #3004777
01/13/22 12:07 AM
01/13/22 12:07 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Let us know how it goes...with pictures...if you find something that pans out. up
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: doctor_mopar] #3004802
01/13/22 08:14 AM
01/13/22 08:14 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Contact Michael Beard at Staging Light Graphics. He made me a set of custom valve cover graphics that looked original. Sorta hard to see but they said "Superstock 451" instead of 426.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: Fat_Mike] #3004876
01/13/22 01:10 PM
01/13/22 01:10 PM
Slidell, La.
Slidell, La.
It may be some time for me to get this done , as I have not swapped out engines yet , and I am gradually getting things together
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: A39Coronet] #3004877
01/13/22 01:11 PM
01/13/22 01:11 PM
Slidell, La.
Slidell, La.
I like the work on your valve cover gaskets . I will have to check with them .
Re: Need 273 air cleaner pie tin for larger air cleaner [Re: doctor_mopar] #3004878
01/13/22 01:13 PM
01/13/22 01:13 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Graphics, not gaskets haha...stupid auto correct. I edited my original post.
