Head flow numbers, which stock one is best #3004194
01/11/22 04:26 PM
01/11/22 04:26 PM
Cab_Burge Offline OP
I'm getting ready to start buying parts for a 6.1 or 6.4 Gen 3 Hemi build to use in my 1967 Satellite, which stock heads flow best?
What do they flow stock and is it a good idea to buy them new from a car dealer?
I've drag race Mopar on the street and track starting in 1964 with my mother's Dodge 270 4 door with one of the first 273 C.I. motor in SO CA back then
The Gen 3 are not in my wheelhouse yet but your never too old to learn, huh devil
I've made 920 HP with a 541 C.I. N/A B1 motors several years back with a single carb on a cast intake manifold, I've built lots of BB wedges and L.A. stroker pump gas motors but no Gen 3 yet shruggy
All help appreciated: up:
Re: Head flow numbers, which stock one is best [Re: Cab_Burge] #3004226
01/11/22 05:28 PM
01/11/22 05:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
6.4 is best, There are two different materials used truck head and car head, the truck head is better but otherwise identical and you would probably never notice the difference. I would lump the 6.2 hell cat head in here as the ports and everything are the same but the intake bolt pattern is different to bolt the stupercharger onto.
6.1 and eagle 5.7 are very similar flow wise but I would take the smaller closed chamber of the 5.7 over the 6.1 head
The worst is the early 5.7 but they flow bone stock about what the best fully ported SB head flows
Re: Head flow numbers, which stock one is best [Re: Cab_Burge] #3004228
01/11/22 05:28 PM
01/11/22 05:28 PM
okla.
sam64 Offline
sam64  Offline
okla.
[I would say the 6.4 and heads are right up there as far as stock heads go,I think they put out 485 HP stock.
Re: Head flow numbers, which stock one is best [Re: Cab_Burge] #3004236
01/11/22 05:36 PM
01/11/22 05:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I always buy mine used, they hardly show any wear and for max performance you would probably want to do your own VJ anyhow and maybe mill to your surface spec and chamber volume.
I don't see where you stated a HP goal but if that 920HP is any indication what you are after your gonna need a heavily ported 6.4 head, most pros are claiming in the ballpark of 400 CFM and a lot more low lift flow than a typical 400CFM wedge head.
A stock 6.4 SRT8 long block makes close to 580 HP with a proper intake manifold, carb and headers bolted on.
Re: Head flow numbers, which stock one is best [Re: HotRodDave] #3004250
01/11/22 05:54 PM
01/11/22 05:54 PM
I'm not looking to build an all-out pump gas motor on my first attempt, if it makes 500+ HP on Oregon pump swill I'll probably be happy up boogie
Re: Head flow numbers, which stock one is best [Re: Cab_Burge] #3004258
01/11/22 06:18 PM
01/11/22 06:18 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My stock T/A 392 is 485 NET flywheel HP factory rating , add headers & a tune & 500 net should be easy
Re: Head flow numbers, which stock one is best [Re: CSK] #3004260
01/11/22 06:28 PM
01/11/22 06:28 PM
Thanks up
I'm thinking of starting to look for a used 6.2 or 6.4 junkyard motor in the spring, April or May luck
I'm debating on which EFI brand and or controller to use also confused help on what to use
I have used Holey Sniper and Terminator EFI systems in the past, but no way do I know enough now to make a wise decision on this deal help
Re: Head flow numbers, which stock one is best [Re: Cab_Burge] #3004263
01/11/22 06:31 PM
01/11/22 06:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Holley has everything you need , have seen people use the HP efi, terminator uses the same HP ecu IIRC just a little different software
Re: Head flow numbers, which stock one is best [Re: CSK] #3005417
01/15/22 12:26 AM
01/15/22 12:26 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
be carefuel here, the terminator and HP use the same ecu, the terminator is not potted ecu (if this matters to you) . ALSO the BIG little detail, the terminator X is not the same as the terminator / HP. it is not nearly as good.
Re: Head flow numbers, which stock one is best [Re: 8urvette] #3005710
01/15/22 07:42 PM
01/15/22 07:42 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Holley makes an entire swap harness for this I think. Dylan used one on that roached out Challenger he put back together.
