Page 3 of 4 1 2 3 4
Re: Project Build.....Dragula Style [Re: Cab_Burge] #2995217
12/14/21 11:54 AM
12/14/21 11:54 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Should be fun...
Re: Project Build.....Dragula Style [Re: Cab_Burge] #2995228
12/14/21 12:17 PM
12/14/21 12:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Quote
That block looks a lot like the World iron blocks looked likework
It should look nearly identical other than the machine work.
It's cast at the same foundry (Dalton) and from the $ame Chry$ler tooling as in 2008.
Congrats on the block Randy.
I remember talking about it back when they first came out through MP/World.
If you sonic it, I'd love to see the numbers posted, and it might help a few folks decide they want one.
The two I checked were super thick esp considering they were both 4.500 and up, but I never
said anything about that activity, as some people here can be ridiculous.
Rich H.
Esse Quam Videri
Re: Project Build.....Dragula Style [Re: ZIPPY] #2995280
12/14/21 02:51 PM
12/14/21 02:51 PM
Dragula Offline OP
Dragula  Offline OP
Originally Posted by ZIPPY
Quote
Its a really clean looking casting. They definitely used some nice tooling when they cast it. The decks look like nearly an inch thick. Machining looks good too, but we have not checked any of it yet. If the money allows, this will become a 528 blown Hemi with an 8-71 on it. I wanted one before they disappear again or the price goes up again.....I would love a wedge version as well, but I have to save what I have for the chassis updates. The guy who welded the cage, is not a chassis guy and it all got cut out. Putting a Moly 8.50 certed cage in it right now.
Re: Project Build.....Dragula Style [Re: Dragula] #2995758
12/16/21 10:35 AM
12/16/21 10:35 AM
gregsdart Offline
gregsdart  Offline
IMHO you are really going in the right direction, both body and motor๐Ÿ‘๐Ÿ‘ Trend makes DLC coated . 990 x . 205 wall piston pins, which I would think might be enough? $ 600 for them though. Any clue what this will weigh? Could it run fast brackets , Quick Sixteen?
Re: Project Build.....Dragula Style [Re: gregsdart] #2995762
12/16/21 10:51 AM
12/16/21 10:51 AM
Dragula Offline OP
Dragula  Offline OP
Well, its funny you ask, because I actually know what it weighs as a roller, and I was shocked....Its already 2000lbs with no drive train! I had it scaled the week I got it. I noticed, after the fact, the rear frame was mandrel bent 2x4 steel instead of the usual 2x3! The damn thing has a Truck sized frame under it!
So my plan is to run this beast on Meth with an 8-71 and make around 1200hp at 12psi or so....So the only things not decided are 528 or 540, and what rotating assembly? Blower will be TBS, and injection will either be Killer Rons or Alky Digger.....With EFI added later.
I just ditched the stock dash and put in a glass one, plus a moly cage....Gonna watch weight where ever I can.
Re: Project Build.....Dragula Style [Re: Dragula] #3000402
12/31/21 06:18 PM
12/31/21 06:18 PM
Dragula Offline OP
Dragula  Offline OP
So the new cage is in. Along with the new fiber glass dash. Looks nice. The old one had to be cut out. It was really bad.
Next problem was seated position and leg room....There just isn't any leg room with the fire wall so far back. I made the decision today to just cut all of it out. The fire wall, the trans tunnel, the floors, everything.
We will then set the engine and trans in it and then the seat and determine where the engine has to be and the new fire wall...What a mess.
Can't live with it the way it is. Trans tunnel is way too big and cramps my foot area bad.
There are so many awesome builds out there, this is where you have to get it right, or you end up selling the car because you hate it. And right now I hate the lack of leg room and how tight everything is. This is especially true for street strip car.
Re: Project Build.....Dragula Style [Re: ZIPPY] #3000653
01/01/22 02:47 PM
01/01/22 02:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Being comfortable in a car is a BIG deal to me. It was the mainreason I sold the Stratus. The new truck most folks cant reach the pedals smile y Valiant was the same way
Re: Project Build.....Dragula Style [Re: Al_Alguire] #3003240
01/08/22 06:32 PM
01/08/22 06:32 PM
Dragula Offline OP
Dragula  Offline OP
Sooooo..No pictures is a bummer....I blame my GF for last week having no pictures as the camera was DOA.....This week, I have picturres, and honestly, there was more car last week, than this week....But I could not live with the interior the way it was, and the cage was a disaster...But we are finally making progress...even though it doesn't look like it.
Re: Project Build.....Dragula Style [Re: Dragula] #3003241
01/08/22 06:35 PM
01/08/22 06:35 PM
Dragula Offline OP
Dragula  Offline OP
Few more..
Re: Project Build.....Dragula Style [Re: Dragula] #3003243
01/08/22 06:37 PM
01/08/22 06:37 PM
Dragula Offline OP
Dragula  Offline OP
Maybe one or two more...
Re: Project Build.....Dragula Style [Re: Dragula] #3003309
01/08/22 10:56 PM
01/08/22 10:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Cool project. Should run strong
Re: Project Build.....Dragula Style [Re: FastmOp] #3003312
01/08/22 11:04 PM
01/08/22 11:04 PM
Dragula Offline OP
Dragula  Offline OP
Its a long way from running...
Re: Project Build.....Dragula Style [Re: Dragula] #3003324
01/08/22 11:52 PM
01/08/22 11:52 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
That is gonna be a neat little Hot Rod! drive boogie
Re: Project Build.....Dragula Style [Re: Dragula] #3003327
01/09/22 12:00 AM
01/09/22 12:00 AM
I can imagine the tall injection stacks sticking up through that hood up bow
Are you going to use EFI with the tube type injection?
I would. up: twocents
Re: Project Build.....Dragula Style [Re: Dragula] #3003388
01/09/22 10:51 AM
01/09/22 10:51 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Randy
That will be a head turner for sure! I know your in the middle of "fixing" it but I notice it doesn't have any horizontal triangulation, do you plan on putting any in?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Project Build.....Dragula Style [Re: Dragula] #3003425
01/09/22 12:40 PM
01/09/22 12:40 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The bones look pretty good now. Gonna be awesome.
Being the looney I am, I'd be in a real fight over painting the body or just clearing it as-is. biggrin
- Stu Harmon
Re: Project Build.....Dragula Style [Re: Dragula] #3003487
01/09/22 03:29 PM
01/09/22 03:29 PM
moparx Offline
moparx  Offline
me thinks you may have had something other than taking pictures on your mind with your GF, then just blamed her for no pictures ! devil whistling biggrin
JUST KIDDING ! laugh2
a question if i may, how close to the rear end is the rear driveshaft loop ? TIA ! bow
and i really LIKE that car ! up
beer
Re: Project Build.....Dragula Style [Re: moparx] #3008656
01/24/22 09:50 PM
01/24/22 09:50 PM
Dragula Offline OP
Dragula  Offline OP
Few more pics....from today.
Re: Project Build.....Dragula Style [Re: Dragula] #3008847
01/25/22 02:02 PM
01/25/22 02:02 PM
moparx Offline
moparx  Offline
beer
Re: Project Build.....Dragula Style [Re: moparx] #3008859
01/25/22 02:21 PM
01/25/22 02:21 PM
Dragula Offline OP
Dragula  Offline OP
Sorry, its not much. I think I need a sponsor.....or at least a winning lottery ticket this hobby eats money.
Comes home this week, and becomes a lawn ornament for a while. Might see if I can get the drive train mounted and then headers built next.
Page 3 of 4 1 2 3 4
