360 swap in a 79 Power Wagon torque converter question #3003060
01/08/22 12:09 AM
01/08/22 12:09 AM
Colorado
dssaa Online content OP
dssaa  Online Content OP
Colorado
Good Evening Moparts...
I have a 1979 Dodge Power Wagon that had a 318 auto....it was seized with broken connecting rods. I came across a 1975 W200 that had a good 360 4/speed in it. I pulled the 360 in hopes of a direct drop into the Power Wagon. Question...since the Power Wagon has a 318 Convertor in it, do I need to swap it for a 360 convertor. I know there were balancing differences between them. I have the motor almost lined up, then it dawned on me that the convertors may be different. Any thoughts?
Appreciate any tips. Was hoping to have the motor in this weekend...now not so sure.
Dave in Colorado
Re: 360 swap in a 79 Power Wagon torque converter question [Re: dssaa] #3003067
01/08/22 01:09 AM
01/08/22 01:09 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Hey Dave wave
Yes the 360 uses a weight on the convertor. There is an early 2 piece weight and a later one piece weight.
I just swap out a 318-727 for a 360 in my 78 D100 and was lucky to have a good 360 convertor sitting here.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 360 swap in a 79 Power Wagon torque converter question [Re: dssaa] #3003074
01/08/22 03:32 AM
01/08/22 03:32 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
B&M External balance flex plate would allow using 318 converter (or other neutral balance converter.) Has stock size 5/16" bolt hole pattern for both big and small converter bolt patterns, and the large 7/16" bolt holes for aftermarket performance converters.
https://www.holley.com/products/drivetrain/flexplates/b_and_m_flexplates/chrysler/parts/10236
CR13 converter has the two small weights, 1600-1800 stall.
CR15H converter has the triangle weight, listed as High Stall (I think 2200?)
Trans Star Converter catalog:
https://www.transtar1.com/TranstarI...verter%20Catalog/mobile/index.html#p=665
Re: 360 swap in a 79 Power Wagon torque converter question [Re: 451Mopar] #3003141
01/08/22 12:24 PM
01/08/22 12:24 PM
Chicago
PurpleBeeper Offline
Chicago
I'm no small block expert, but my gut instinct would be to use the flexplate and keep your current converter.....OR, if you want an aftermarket converter, there are normally a lot more choices for "neutral balance" converters. Again, I'm no expert on small blocks, but I've run into similar situations with externally balanced big block engines
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 360 swap in a 79 Power Wagon torque converter question [Re: PurpleBeeper] #3003176
01/08/22 02:42 PM
01/08/22 02:42 PM
moparx Offline
moparx  Offline
this is a timely post for me.
i have been asked about installing a 360 in a 1970 fury, but keeping the original 904.
without going into why this is a bad idea, has anyone added the weight from a 727 converter to a 904 converter ?
the chassis book shows where to put the weight, and how many grams it must weigh.
i know the B&M flexplate is the best way to go, but i'm just curious if anyone has added the weight to the 904 converter.
as always, TIA ! bow
beer
Re: 360 swap in a 79 Power Wagon torque converter question [Re: moparx] #3003190
01/08/22 02:58 PM
01/08/22 02:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
I added the weights from the old MP kit to a 727 converter when I went from 413 to 400. Not exactly the same but no issues doing it.
I don't think the type of trans matters, just the type of engine.
Re: 360 swap in a 79 Power Wagon torque converter question [Re: Sniper] #3003195
01/08/22 03:07 PM
01/08/22 03:07 PM
moparx Offline
moparx  Offline
thanks. those were my thoughts as well. balance for the engine in use.
beer
Re: 360 swap in a 79 Power Wagon torque converter question [Re: moparx] #3003206
01/08/22 03:50 PM
01/08/22 03:50 PM
5thAve Offline
5thAve  Offline
I've always paid a transmission shop to add the weight and they supplied it. I would have gone with the B&M plate and I'd pick one up if I ever saw it for a great price somewhere like a swap meet but this was quicker and cheaper.
