SIDE BAR #3002810
01/07/22 09:19 AM
01/07/22 09:19 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
HI,
other then being made with PVC is this a good or bad design, 67 years old a little harder to get in and out, don't care for swing out bars
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: SIDE BAR [Re: 440lebaron] #3002856
01/07/22 12:56 PM
01/07/22 12:56 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Doubt that will pass NHRA tech. That is of course if your track actually techs your car.
Re: SIDE BAR [Re: DusterKid] #3002880
01/07/22 02:16 PM
01/07/22 02:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Nope.
Must pass between your shoulder and elbow when in normal seated position.
Swing out bar is the only option.
Or as stated, only race at places that don't check or care.
I have done stuff like that in the past for restomod street cars with the understanding it would not pass tech. Owners were OK with that.
Re: SIDE BAR [Re: CMcAllister] #3002890
01/07/22 02:56 PM
01/07/22 02:56 PM
westerly, ri. usa
westerly, ri. usa
i can move seat back some and raise bar, would make elbow 1-2 inches below bar, will be teched at nat events, was concerned about having bend in bar
Re: SIDE BAR [Re: 440lebaron] #3002923
01/07/22 04:38 PM
01/07/22 04:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Just put a swing out in it.
Re: SIDE BAR [Re: 440lebaron] #3002927
01/07/22 04:44 PM
01/07/22 04:44 PM
Contact NHRA tech to be safe twocents scope up
Re: SIDE BAR [Re: 440lebaron] #3003126
01/08/22 11:44 AM
01/08/22 11:44 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would check with whomever is going to do your chassis certification.
I had a question about my cage several years ago when I started planning to run NHRA Superstock.
Neither the regional tech director or the national office would answer my questions about what I thought might be a deficiency.
They both just said, get it inspected. I did and I got a sticker with no issues and no issues since then.
Re: SIDE BAR [Re: 340Cuda] #3003174
01/08/22 02:40 PM
01/08/22 02:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
This is a stocker and/or just a bar as opposed to a cage? No cert.
Going to divisionals and national events? It needs to be right. They will put you in the car and look at it if there's a question. They will make you cut it out if they don't like it.
Rulebook is cut and dry. The guy doing the inspection is the one who will decide, but I always went by the book and planned for the hardass.
"Sidebar must be included on driver's side and must pass the driver at a point midway between the shoulder and elbow. Swing out side bar permitted."
