Possible fuel leak. #3002432
01/05/22 10:19 PM
01/05/22 10:19 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Re: Possible fuel leak. [Re: Vert] #3002437
01/05/22 10:32 PM
01/05/22 10:32 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
13 psi to an Edelbrock is asking for it.
Re: Possible fuel leak. [Re: Sniper] #3002455
01/05/22 11:16 PM
01/05/22 11:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Old or new lines?
Re: Possible fuel leak. [Re: Sniper] #3002457
01/05/22 11:30 PM
01/05/22 11:30 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Thats what I'm thinking. I'm making a new line for that carb, and cutting the pressure.
Re: Possible fuel leak. [Re: NITROUSN] #3002458
01/05/22 11:31 PM
01/05/22 11:31 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Prob 2-3 yrs. Car has been sitting a long time.
Re: Possible fuel leak. [Re: Vert] #3002562
01/06/22 11:59 AM
01/06/22 11:59 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Just looking at the video it looks like the section of hose itself is the source of the leak. My first thought was the fittings but it looks like it's coming from the bend in the braided hose.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Possible fuel leak. [Re: wingman] #3002570
01/06/22 12:22 PM
01/06/22 12:22 PM
moparx Offline
moparx  Offline
i vote for the hose being bad as well. at the beginning of the leak, there appears to be a brief "puff" of fuel at the bend before the leak appears to go up the hose toward the regulator.
at least that's how my old eyeballs see it.
beer
Re: Possible fuel leak. [Re: Vert] #3002609
01/06/22 02:27 PM
01/06/22 02:27 PM
If that hose is neoprene or rubber it is done sealing from sitting and old age down
You should use Teflon line hose on all oil, fuel and brake lines from now on up scope They live forever and don't leak wrench twocents
Re: Possible fuel leak. [Re: Cab_Burge] #3002610
01/06/22 02:30 PM
01/06/22 02:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think the hose is leaking. i'd try another gauge to verify the existing.
Re: Possible fuel leak. [Re: lewtot184] #3002624
01/06/22 03:38 PM
01/06/22 03:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I see a few things:
Hose at carb fitting doesn't look fully seated, appears angled.
Tough combination of angles, I'd prefer a "U" rather than an "S" that tight.
13PSI is a ton; though the hose & fittings should be rated much higher, the carb should be unhappy.
Interesting how it seems to bleed right through the hose, but I wonder if it starts at the hose end/carb fitting...
Re: Possible fuel leak. [Re: topside] #3002670
01/06/22 06:06 PM
01/06/22 06:06 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The fitting on the end isn't installed properly. my guess is thats the problem . Look at the gap between the the fitting hex and the collar nut.
Re: Possible fuel leak. [Re: B1MAXX] #3002683
01/06/22 06:39 PM
01/06/22 06:39 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Could be hose but it looks like the fitting is not cranked down enough...if it was an older braided hose then yes the hose..it happened to me..then it stopped..but I replaced it anyways
https://youtu.be/nYYmUj2hbDk
Re: Possible fuel leak. [Re: AARCONV] #3002799
01/07/22 08:08 AM
01/07/22 08:08 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I've had bad hose also, right out of the box once, but that fitting looks wrong right off the bat.
Re: Possible fuel leak. [Re: B1MAXX] #3002800
01/07/22 08:17 AM
01/07/22 08:17 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Just watched it again in half speed looks like it a failed hose. I see the dampness going up the braid, not to mention the short spray out of it at the beginning.
Re: Possible fuel leak. [Re: B1MAXX] #3002891
01/07/22 03:00 PM
01/07/22 03:00 PM
moparx Offline
moparx  Offline
i'm glad you saw that spray MAXX. i was hoping i wasn't seeing things.
i tried to get the video to slow down, but i can't seem to get it to do what i want, so i must be doing something wrong. [ya know, old guys and these new fangled 'lectric thingys..... biggrin]
beer
Re: Possible fuel leak. [Re: moparx] #3002963
01/07/22 06:24 PM
01/07/22 06:24 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
There is a little icon in the lower corner on you tube vids that looks like a little gear with all the teeth rounded off to slow it down. I think its called settings if you hover on it.
Re: Possible fuel leak. [Re: B1MAXX] #3002996
01/07/22 08:03 PM
01/07/22 08:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I saw the spray as well, but I'm not sure it's not from the engine's fan, if it has one.
But that could reinforce the thinking that the hose itself is leaking.
Re: Possible fuel leak. [Re: B1MAXX] #3003160
01/08/22 01:47 PM
01/08/22 01:47 PM
moparx Offline
moparx  Offline
thanks MAXX ! that did it ! up
i slowed it down to the slowest setting, and that spray sure seems to be coming from the bend in the hose first, then runs up and down the hose.
beer
