1970 seats in 1969 Swingers #3000639
01/01/22 02:27 PM
01/01/22 02:27 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Has anyone run across a late build 69 Swinger 340 with 1970 seats from the factory? Build date June 69.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3000749
01/01/22 05:49 PM
01/01/22 05:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Nope.
There was a discussion here years ago about 69 Swingers getting bucket seat at all.
Bottom lineā€¦ what does the fender tag say?
Re: 1970 seats in 1969 Swingers [Re: autoxcuda] #3000981
01/02/22 12:01 AM
01/02/22 12:01 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Not talking about bucket seats. 1970 bench seat with set back release up on side of seat backs.
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3000984
01/02/22 12:15 AM
01/02/22 12:15 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Shouldn't happen but could have. I know the used the 1970 lower core support starting around May 1969 as I have several of those cars that had them originally. I have seen and documented a 69 Swinger 340 with factory bucket seats also and they were not an available option... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3000993
01/02/22 12:54 AM
01/02/22 12:54 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Does the bench seat have a 1970 design/pattern? Do the rear seats also?
What does the fender tag say? Notes on Buildsheet?
Re: 1970 seats in 1969 Swingers [Re: autoxcuda] #3001130
01/02/22 02:24 PM
01/02/22 02:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Long shot question, what color is or was the car, and 4 spd or auto? popcorn
Re: 1970 seats in 1969 Swingers [Re: autoxcuda] #3001796
01/03/22 11:11 PM
01/03/22 11:11 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Front seat has the 70 design. Rear is 69. Fender tag shows D2X
No notes on build sheet
Re: 1970 seats in 1969 Swingers [Re: TJP] #3001797
01/03/22 11:12 PM
01/03/22 11:12 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Car is and was R4 and auto.
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3001830
01/04/22 12:32 AM
01/04/22 12:32 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I understand that they are 70 and 69 "design", but do they both have the same cover pattern? shruggy
A-Body's RULE!
Re: 1970 seats in 1969 Swingers [Re: Rhinodart] #3001915
01/04/22 11:31 AM
01/04/22 11:31 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
When I say 70 design, I mean seat release up on side of seat. The upholstery pattern is pretty much the same.
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3001930
01/04/22 12:35 PM
01/04/22 12:35 PM
moparx Offline
moparx  Offline
i would think if the upholstery pattern is not exact, then the seat has been changed.
just my opinion. your mileage will vary.
beer
Re: 1970 seats in 1969 Swingers [Re: moparx] #3001953
01/04/22 01:26 PM
01/04/22 01:26 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Unless the car was a very late build - what's the SPD? - I doubt that happened on the assembly line.
While I don't know why the seat would be changed, 50 years is a long time...
Re: 1970 seats in 1969 Swingers [Re: topside] #3002012
01/04/22 03:25 PM
01/04/22 03:25 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Car was built in early June. Jim (RhinoDart) said he remembered a car fitting the description back in the day with bucket seats.
Maybe this is the same car that had the bench put back in many moons ago, but used a 70 front seat instead of the correct 69.
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3002023
01/04/22 04:00 PM
01/04/22 04:00 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I have original upholstery bench seats from both 69 and 70 Swingers sitting in my basement. The upholstery pattern is the same and they both have the seat back releases in the same area on the upper side of the seat back.
Re: 1970 seats in 1969 Swingers [Re: 6T9Hemi] #3002145
01/04/22 10:15 PM
01/04/22 10:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
had an R4 4sp car that the later seats were put in back in the late 70's. however it was an original 4spd car. At one point it had an auto in it but later switched back to a 4spd. thanks for replying beer
Re: 1970 seats in 1969 Swingers [Re: TJP] #3002147
01/04/22 10:20 PM
01/04/22 10:20 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Have you removed the seat? There should be an aluminum tag attached to a seat spring, with the production info and stamped date of assembly. May find a build sheet there as well. That would be pretty definitive.
Re: 1970 seats in 1969 Swingers [Re: Jer] #3002186
01/05/22 12:14 AM
01/05/22 12:14 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There are two different patterns for the 69 Swinger bench seat, regular and deluxe. Can you post some pics?
A-Body's RULE!
Re: 1970 seats in 1969 Swingers [Re: Rhinodart] #3002244
01/05/22 11:37 AM
01/05/22 11:37 AM
A collage of whims
A collage of whims
The base has a flat textured seating surface, and the deluxe has the pleats (think tuck & roll), IIRC.
Re: 1970 seats in 1969 Swingers [Re: topside] #3002438
01/05/22 10:33 PM
01/05/22 10:33 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes, the 70 also had the same, just sold a base 70 bench seat in green that had the same pattern as the base 69 Swinger...
A-Body's RULE!
Re: 1970 seats in 1969 Swingers [Re: 6PAX] #3002452
01/05/22 11:00 PM
01/05/22 11:00 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
I have never seen a 69 340 Swinger with the seat release up on the side of the seat backs.
