New Small block #3001149
01/02/22 02:55 PM
01/02/22 02:55 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I don't know if anyone noticed this at PRI but it looked interesting for the Small Block guys.
Re: New Small block [Re: fbs63] #3001153
01/02/22 03:02 PM
01/02/22 03:02 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ut oh, small block post...Somebody notify the "better to build a gen 3" crowd quick!
Re: New Small block [Re: Hot 340] #3001176
01/02/22 04:04 PM
01/02/22 04:04 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
It’s the multi block
Re: New Small block [Re: RAY1969CARS] #3001213
01/02/22 05:24 PM
01/02/22 05:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'd guess a 'universal' type block would require you to figure out your own intake setup?
I think I'd rather have a Ritter block, assuming its correctly built and all that, before diving into a universal engine block if they are both equally durable and function the same in a street/strip car.
Re: New Small block [Re: Neil] #3001232
01/02/22 05:58 PM
01/02/22 05:58 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
The bock that goes Both ways. !!! 😂😂😂 Not that there’s anything wrong with that 🤣🤣 Brought to you by the people that make the 10 in one screwdriver
Re: New Small block [Re: RAY1969CARS] #3001261
01/02/22 07:15 PM
01/02/22 07:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hmmm...china walls look like SBC, and the head bolt arrangement is interesting, some 4- & some 5-bolt.
Looks like a ton of water jacket too.
I too wonder about an intake, and for that matter the front cover and engine-mounting locations.
Interesting idea, though.
Re: New Small block [Re: topside] #3001878
01/04/22 09:39 AM
01/04/22 09:39 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice find Bob. Any more details? When available? Cost? Has anyone built any platforms with it yet? When are you going to buy one?
Re: New Small block [Re: fbs63] #3001901
01/04/22 10:55 AM
01/04/22 10:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A small block with Mopar heads and the distributor standing straight up in the front, that would blow some minds! shock
Re: New Small block [Re: justinp61] #3001940
01/04/22 01:01 PM
01/04/22 01:01 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Web page?
Re: New Small block [Re: justinp61] #3002003
01/04/22 03:01 PM
01/04/22 03:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Re: New Small block [Re: CMcAllister] #3002083
01/04/22 07:26 PM
01/04/22 07:26 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Small block ford with mopar valve covers is pretty much what a R6 motor is
Re: New Small block [Re: Leigh] #3002226
01/05/22 10:05 AM
01/05/22 10:05 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Originally Posted by Leigh
Web page?
There is a website listed in the small print in the lower left corner on the first page in Bob's post, www.1spec.net which is not found. A google search for 1spec comes up with nothing but what is interesting is the street address for 1spec listed is the same as M&M Competition Engines in Franklin, IN. but there is no mention of 1spec on M&M's website. https://mmcompetitionengines.com/
1421 Amy Ln. Suite A
Franklin, IN 46131
Phone: 317-739-3187
Fax: 317-739-3189
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: New Small block [Re: Plumb Wired] #3002320
01/05/22 03:54 PM
01/05/22 03:54 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yes, I didn’t find anything either.
Re: New Small block [Re: Leigh] #3002355
01/05/22 06:18 PM
01/05/22 06:18 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I tried to work with Dart, several years ago, on a generic block that would work with Mopar top end. A standardized short block that could be machined to fit the aftermarket LA heads, use some cheaper GM bottom end parts and make 2000+HP. Didn't have any traction. This looks promising.
Re: New Small block [Re: scottb] #3002386
01/05/22 07:53 PM
01/05/22 07:53 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Other than having the distibutor in the front, I am not sure why you're think that. They have a 4.5" bore spacing and a mirror type port lay out, like the SB2.2, P7 and TRD heads.
Best I can tell, all the current Nascar stuff has the distributor in the front now.
Alan Jones
Re: New Small block [Re: LA360] #3002399
01/05/22 08:55 PM
01/05/22 08:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
These days, whatever name is cast or engraved in the valve cover, that's what it is.
Re: New Small block [Re: LA360] #3002417
01/05/22 09:46 PM
01/05/22 09:46 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
P7 heads will not fit on a R6 block and the R6 block and heads were based off the Ford motor right from the head engine builder at Penske
Re: New Small block [Re: scottb] #3002464
01/05/22 11:50 PM
01/05/22 11:50 PM
LA360 Offline
LA360  Offline
I am well aware the P7 heads won't fit, I used it and other as examples of heads with the mirror port layout.
Alan Jones
Re: New Small block [Re: LA360] #3002499
01/06/22 08:03 AM
01/06/22 08:03 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Being developed by M&M Competition Engines. They also make cast tunnel ram style intakes that fit various platforms. 1spec is the foundry that casts the parts. They are also casting a Gen III Hemi head for MMX. I figured guys would be interested since R blocks are scarce. I almost walked right by at PRI till I noticed the Gen III head. Started looking at the stuff and noticed the block. Would be an interesting combo with a 9.800 deck, stroke and P7 heads. I'm sure they can make a cast manifold.
HardcoreB
I'm to invested in a Gen III Hemi to start over. Everything for my 63 is fabbed for that so no changing direction now. Does peak my interest though. Be a GREAT motor for NA 10.5!
Re: New Small block [Re: fbs63] #3002502
01/06/22 08:30 AM
01/06/22 08:30 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
awesome!
