Re: New Small block
[Re: fbs63]
#3002696
01/06/22 07:35 PM
01/06/22 07:35 PM
Posts: 6,142 Melbourne , Australia
LA360
Being developed by M&M Competition Engines. They also make cast tunnel ram style intakes that fit various platforms. 1spec is the foundry that casts the parts. They are also casting a Gen III Hemi head for MMX. I figured guys would be interested since R blocks are scarce. I almost walked right by at PRI till I noticed the Gen III head. Started looking at the stuff and noticed the block. Would be an interesting combo with a 9.800 deck, stroke and P7 heads. I'm sure they can make a cast manifold.
HardcoreB I'm to invested in a Gen III Hemi to start over. Everything for my 63 is fabbed for that so no changing direction now. Does peak my interest though. Be a GREAT motor for NA 10.5! It's cool to see new stuff come out, however the Ritter XR2 is available in 9.6" and 9.2" deck heights and I think I've seen about 2 or 3 builds with one.
Alan Jones
Re: New Small block
[Re: LA360]
#3002757
01/06/22 11:00 PM
01/06/22 11:00 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Ritters can be built for P7 heads. I believe the guys local to me have that one figured out.
Re: New Small block
[Re: LA360]
#3002811
01/07/22 09:27 AM
01/07/22 09:27 AM
Posts: 164 W. Pa
usp4u
W. Pa
HardcoreB I'm to invested in a Gen III Hemi to start over. Everything for my 63 is fabbed for that so no changing direction now. Does peak my interest though. Be a GREAT motor for NA 10.5! It's cool to see new stuff come out, however the Ritter XR2 is available in 9.6" and 9.2" deck heights and I think I've seen about 2 or 3 builds with one. There has been a dozen or more Ritter builds with the v2.0 block and they are figured out pretty well. Back in May I was at Harshman's shop and there were about 5-6 sitting there awaiting machining.
Re: New Small block
[Re: fbs63]
#3002820
01/07/22 10:58 AM
01/07/22 10:58 AM
Posts: 4,049 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Being developed by M&M Competition Engines. ... Does peak my interest though. Be a GREAT motor for NA 10.5! Yes definitely has some potential! From what i see, based on the parity of rules structuring, the B1 BBM would be an equal player. Both wind up about the same weight. For 2022, I'm staying in my wheelhouse and just using what i have. Unlikely I'll do any NMCA. But the chatter is local tracks are adopting NMCA rules so, that's the direction I'm headed. pun intended
Re: New Small block
[Re: usp4u]
#3003669
01/09/22 11:32 PM
01/09/22 11:32 PM
LA360
HardcoreB I'm to invested in a Gen III Hemi to start over. Everything for my 63 is fabbed for that so no changing direction now. Does peak my interest though. Be a GREAT motor for NA 10.5! It's cool to see new stuff come out, however the Ritter XR2 is available in 9.6" and 9.2" deck heights and I think I've seen about 2 or 3 builds with one. There has been a dozen or more Ritter builds with the v2.0 block and they are figured out pretty well. Back in May I was at Harshman's shop and there were about 5-6 sitting there awaiting machining. Are you talking about the XR1 block for wedge heads? Or the XR2 for P7 heads?
Alan Jones
