Re: New Small block
[Re: Neil]
#3001232
01/02/22 05:58 PM
01/02/22 05:58 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
The bock that goes Both ways. !!! 😂😂😂 Not that there’s anything wrong with that 🤣🤣 Brought to you by the people that make the 10 in one screwdriver
Re: New Small block
[Re: Leigh]
#3002226
01/05/22 10:05 AM
01/05/22 10:05 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
There is a website listed in the small print in the lower left corner on the first page in Bob's post, www.1spec.net which is not found. A google search for 1spec comes up with nothing but what is interesting is the street address for 1spec listed is the same as M&M Competition Engines in Franklin, IN. but there is no mention of 1spec on M&M's website. https://mmcompetitionengines.com/M&M Competition Engines 1421 Amy Ln. Suite A Franklin, IN 46131 Phone: 317-739-3187 Fax: 317-739-3189
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
Re: New Small block
[Re: scottb]
#3002386
01/05/22 07:53 PM
01/05/22 07:53 PM
Posts: 6,149 Melbourne , Australia
LA360
Small block ford with mopar valve covers is pretty much what a R6 motor is Other than having the distibutor in the front, I am not sure why you're think that. They have a 4.5" bore spacing and a mirror type port lay out, like the SB2.2, P7 and TRD heads. Best I can tell, all the current Nascar stuff has the distributor in the front now.
Alan Jones
Re: New Small block
[Re: scottb]
#3002464
01/05/22 11:50 PM
01/05/22 11:50 PM
LA360
P7 heads will not fit on a R6 block and the R6 block and heads were based off the Ford motor right from the head engine builder at Penske I am well aware the P7 heads won't fit, I used it and other as examples of heads with the mirror port layout.
Alan Jones
Re: New Small block
[Re: LA360]
#3002499
01/06/22 08:03 AM
01/06/22 08:03 AM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
Being developed by M&M Competition Engines. They also make cast tunnel ram style intakes that fit various platforms. 1spec is the foundry that casts the parts. They are also casting a Gen III Hemi head for MMX. I figured guys would be interested since R blocks are scarce. I almost walked right by at PRI till I noticed the Gen III head. Started looking at the stuff and noticed the block. Would be an interesting combo with a 9.800 deck, stroke and P7 heads. I'm sure they can make a cast manifold.
HardcoreB I'm to invested in a Gen III Hemi to start over. Everything for my 63 is fabbed for that so no changing direction now. Does peak my interest though. Be a GREAT motor for NA 10.5!
