Page 3 of 3 1 2 3
Re: What causes front tires to turn outwards during wheelie [Re: dvw] #3001037
01/02/22 10:04 AM
01/02/22 10:04 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
You could have tie rod length same as lca and have same toe issues. That indicates that the two are in different arc. toe out is the least desirable you have to play with outer tie rod heights until you get the least of toe change. look in mopar chassis book it shows how to do this by making a sweep graph. .That is why we heat and bend the tie rod mount at the end of the lower ball joint or get adjuster kit and use hime joints.
JAKES AUTOMOTIVE
Re: What causes front tires to turn outwards during wheelie [Re: MoonshineMattK] #3001050
01/02/22 10:59 AM
01/02/22 10:59 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Originally Posted by MoonshineMattK
https://www.youtube.com/watch?v=bP4gi4jr9oU
This probably wont help but Herb talks about it here. Interesting video none the less.
Thanks, that was a great video! up He did mention how he worked on the front end to make sure the tires moved up and down straight....
Re: What causes front tires to turn outwards during wheelie [Re: JAKE68] #3001053
01/02/22 11:05 AM
01/02/22 11:05 AM
Houston, Texas
Houston, Texas
I am unable to find a copy of this on Amazon, etc... If it is not too much trouble, could you post a pic/copy of this section: making a sweep graph.
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #3001059
01/02/22 11:28 AM
01/02/22 11:28 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My buddy Patrick made a bump steer gauge and plotted mine on the Valiant when he remounted the rack. I think he found a video on YouTube showing how to do it.
Re: What causes front tires to turn outwards during wheelie [Re: slantzilla] #3001117
01/02/22 01:52 PM
01/02/22 01:52 PM
Houston, Texas
Houston, Texas
Just a quick search: https://www.youtube.com/watch?v=bSCLJkZN3cs
Has anyone tried this?
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #3001120
01/02/22 02:06 PM
01/02/22 02:06 PM
moparx Offline
moparx  Offline
i think i can make a PDF file of this from the chassis manual, showing plotting graphs.
then send it to you ?
beer
Re: What causes front tires to turn outwards during wheelie [Re: moparx] #3001122
01/02/22 02:09 PM
01/02/22 02:09 PM
Houston, Texas
Houston, Texas
beer
That would be great! Jsintexas2 domain is yahoo
After a bit more reading, I fully understand what the issue is... now, I am just trying to determine what the easiest/best way is to resolve it.
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #3001124
01/02/22 02:13 PM
01/02/22 02:13 PM
moparx Offline
moparx  Offline
i will get on it and report back in a bit.............
beer
Re: What causes front tires to turn outwards during wheelie [Re: moparx] #3001134
01/02/22 02:38 PM
01/02/22 02:38 PM
moparx Offline
moparx  Offline
ok........... got a 13 page PDF from the chassis book on how to fix and plot bump steer.
if anyone wants a copy, pm me with e-mail address, and i will send it to you. put # 106 in the request.
beer
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #3001139
01/02/22 02:42 PM
01/02/22 02:42 PM
moparx Offline
moparx  Offline
on it's way. subject will be "chassis manual".
please let me know if you get it. i have been known to "screw up" even the most simplest things, like being able to break an anvil with a feather. biggrin
beer
Re: What causes front tires to turn outwards during wheelie [Re: moparx] #3001157
01/02/22 03:18 PM
01/02/22 03:18 PM
Houston, Texas
Houston, Texas
beer
Got it! Many thanks! dakota drive
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #3001171
01/02/22 03:58 PM
01/02/22 03:58 PM
moparx Offline
moparx  Offline
not a problem !
if you need anything else from that manual, give me a shout. up
beer
Page 3 of 3 1 2 3
