AR ENGINEERING VALLEY PLATE #3000649
01/01/22 02:40 PM
01/01/22 02:40 PM
Fairview Tennessee
SV_MOPARS Offline OP
Fairview Tennessee
i think i already know the answer but just looking for info on using the ar engineering (andy f) valley plate part #ar182a under a new aluminum 6 pack intake on a rb block with trick flow 240 heads, i know i need the batwings and 4 gaskets, are there any clearance issues on the bottom of intake to deal with or will this setup work at all?
Re: AR ENGINEERING VALLEY PLATE [Re: SV_MOPARS] #3000661
01/01/22 03:06 PM
01/01/22 03:06 PM
AndyF Offline
AndyF  Offline
You'll need to remove the exhaust gas crossover on the bottom of the intake. Mock it up and you'll understand.
Re: AR ENGINEERING VALLEY PLATE [Re: SV_MOPARS] #3000672
01/01/22 03:32 PM
01/01/22 03:32 PM
Chicago
PurpleBeeper Offline
Chicago
I've been looking into this as well. I would like to run a valley plate with my six pack setup too. However, all the valley plates I've found are flat across (except one modified for one particular intake). The six pack intakes "dip down into the valley" of the valley pan. I never considered grinding off a huge section of the bottom of the six pack intake, but I suppose that would work. Many years ago I basically made my own valley plate by cutting up a stock valley pan and using TONS of RTV silicone and I sealed the intake runners with one set of paper gaskets.
Be advised....you "probably" won't need any of those paper gaskets although every old Mopar book you read says you need them. My block was decked .040" and my heads .020" (fyi). I was unable to use even ONE of those gaskets on each side, let alone both gaskets. My intake barely bolts up with ONLY the factory valley pan.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: AR ENGINEERING VALLEY PLATE [Re: PurpleBeeper] #3000681
01/01/22 03:56 PM
01/01/22 03:56 PM
Fairview Tennessee
Fairview Tennessee
Thanks andy. to the second post, yes i have always used just the factory style valley pan without gaskets but added sealant to both sides, im not sure that can be done with the batwings that andy has, im sure he will chime in.
Re: AR ENGINEERING VALLEY PLATE [Re: SV_MOPARS] #3000685
01/01/22 04:01 PM
01/01/22 04:01 PM
AndyF Offline
AndyF  Offline
If it is a factory six pack intake then you most likely don't want to ruin it by removing the cross over. If it is an aftermarket one then just cut off the crossover since you don't need it anyway with the TF240 heads. The crossover is just extra weight when using Trick Flow heads.
Re: AR ENGINEERING VALLEY PLATE [Re: AndyF] #3000694
01/01/22 04:08 PM
01/01/22 04:08 PM
Fairview Tennessee
Fairview Tennessee
its not an original six pack mani. can the batwings be installed with just sealant or do they require gaskets and sealant? maybe the batwings come with instructions, not sure.
Re: AR ENGINEERING VALLEY PLATE [Re: SV_MOPARS] #3000757
01/01/22 05:58 PM
01/01/22 05:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
made this many years ago. the recess is 6 pak specific. either you cut in a recess or remove the crossover chamber.
Re: AR ENGINEERING VALLEY PLATE [Re: lewtot184] #3000764
01/01/22 06:05 PM
01/01/22 06:05 PM
Fairview Tennessee
Fairview Tennessee
Nice, that might work, although at this point im leaning towards the AR setup.
Re: AR ENGINEERING VALLEY PLATE [Re: SV_MOPARS] #3000775
01/01/22 06:25 PM
01/01/22 06:25 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If it doesn't have to look stock, and you have room, seems to me adding an oil-fill neck would be handy.
Re: AR ENGINEERING VALLEY PLATE [Re: topside] #3001020
01/02/22 08:17 AM
01/02/22 08:17 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
in early 2003 i made that valley cover for a 6 pak engine i was building. i had always fought the sucking oil thru the intake problem and was looking for a permanent cure. i used it for quite a few years without any issues, but eventually moved away from the idea. i regret not making something with a more universal fit but at the time i was pretty much stuck on 6 paks. i got to where i just addressed the manifold fitment issues directly and left the "band-aid" behind.
Re: AR ENGINEERING VALLEY PLATE [Re: topside] #3001077
01/02/22 12:30 PM
01/02/22 12:30 PM
AndyF Offline
AndyF  Offline
I put #12 AN o-ring bosses in a few valley covers. The idea works fine but it adds a lot of extra expense to the design.
