Re: What is a good rust preventive spray for storing a block
[Re: ragtop]
#3000608
01/01/22 01:12 PM
01/01/22 01:12 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What would you recommend for a spray on rust protector for storing an engine block? Thank you. Freshly machined or right out of a car? If freshly machined, heavy grease on the machined surfaces, Glyptol on the inner cast surfaces and the paint you intend to use on the exterior.
[Re: AndyF]
#3000629
01/01/22 01:49 PM
01/01/22 01:49 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Just paint it with a cheap spray paint and then in the future have it hot tanked to remove the paint. This is what my machine shop says too, and they have tried everything else.
[Re: 4406bbl]
#3000679
01/01/22 03:54 PM
01/01/22 03:54 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
i have had pretty good luck with spraying parts down with a heavy coat of spray white lithium grease.
perception is 90% of reality
[Re: 4406bbl]
#3000682
01/01/22 03:58 PM
01/01/22 03:58 PM
Posts: 31,023 Oregon
AndyF
Just paint it with a cheap spray paint and then in the future have it hot tanked to remove the paint. This is what my machine shop says too, and they have tried everything else. Yeah I've tried grease and oil and lube sprays and other protectant sprays. Finally just decided that cheap engine paint is the easiest since the blocks always get hot tanked again before the shop starts the rebuild process. When I buy a block now I take it apart, get it hot tanked and then spray it with cheap paint.
[Re: 4406bbl]
#3000684
01/01/22 04:00 PM
01/01/22 04:00 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
i have used this .... it is very good. i even put it on the lug nuts on boat trailers! it does not wash off after many times in and out of the water ! it forms a gel like paste when dry... i love it..it works .it claims 2 years inside but it last longer when a block is in an air tight bag
[Re: MoparMike1974]
#3005444
01/15/22 02:02 AM
01/15/22 02:02 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Gibbs lubricant works very well, so does motorcycle chain lube spray, spray lithium grease, and smearing grease all over it. What ever you use, it is a good idea to check on it every now and then just to make sure no rust is starting.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
