K member coin 52 applications #2999631
12/29/21 06:53 PM
12/29/21 06:53 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have a #52 K-member, I'm seeing conflicting info on what engines it was used with.
Please have a look at the attachments.
I would like to put in a big block. Will that work ?
Hmm, I guess you have to click on the TXT file to see it.
70-K.txt (34 downloads)
Re: K member coin 52 applications [Re: hemienvy] #2999642
12/29/21 07:29 PM
12/29/21 07:29 PM
BDW Offline
BDW  Offline
All V8's (except Hemi) can use same K-frame
Re: K member coin 52 applications [Re: hemienvy] #2999676
12/29/21 08:39 PM
12/29/21 08:39 PM
Chicago
PurpleBeeper Offline
Chicago
As far as I know, the "coins" were only used on Hemi/Six Pack k-members (at least in b bodies). They have a skid plate welded on them, about 3 inches tall roughly, WOW interesting stuff below. I had no idea
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: K member coin 52 applications [Re: PurpleBeeper] #2999708
12/29/21 09:35 PM
12/29/21 09:35 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK thanks fellers, I guess I'm safe.
I got this K-frame separate, my 70 BCuda project had a 225-6 and a 10 coin.
Re: K member coin 52 applications [Re: hemienvy] #2999772
12/30/21 01:27 AM
12/30/21 01:27 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Good luck with your project up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: K member coin 52 applications [Re: BloFish] #2999786
12/30/21 06:27 AM
12/30/21 06:27 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have two 340 AAR Cudas and they both have the 52 coin. I have a late 340 Cuda with the 52 coin as well. I’ve got several other k frames that I have not really checked the coins. It will work with a big block.
Re: K member coin 52 applications [Re: fastmark] #3000018
12/30/21 04:44 PM
12/30/21 04:44 PM
Independence
69 MBee Offline
69 MBee  Offline
Independence
Aren't the coins simply the last two digits of the part number??
Re: K member coin 52 applications [Re: 69 MBee] #3000211
12/31/21 07:05 AM
12/31/21 07:05 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes.
Re: K member coin 52 applications [Re: hemienvy] #3000245
12/31/21 11:41 AM
12/31/21 11:41 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 3583052 K-frame was introduced during the 1970 model year (replacing the 2962012 K-frame)
The 52 was used on E-bodies with 318s, 340, 340-6 and 383 engines.
Re: K member coin 52 applications [Re: Alaskan_TA] #3000298
12/31/21 02:02 PM
12/31/21 02:02 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
52 is on my Broadcast Sheet under K Frame and K Member part number (No coin, No Skid Plate) also for my December built 1971 Superbee - 383
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: K member coin 52 applications [Re: bee1971] #3010481
01/30/22 09:43 AM
01/30/22 09:43 AM
BDW Offline
BDW  Offline
My 52 has a skid plate
Re: K member coin 52 applications [Re: BDW] #3011277
02/01/22 07:31 PM
02/01/22 07:31 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
5e coins started in mid model year 1970.
The 52 doesn’t have a skid plate from the factory, but the aftermarket has been selling skid plates for years.
