Page 2 of 3 1 2 3
Re: Header design, merge collectors? [Re: gregsdart] #2999795
12/30/21 08:33 AM
12/30/21 08:33 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Brian Smith makes those header flanges. He used to be a member here, but have not seen him in a long time. He is on Facebook though. You will not find a nicer header collector piece than he makes.
69 GTX 68 Road Runner
Re: Header design, merge collectors? [Re: JERICOGTX] #2999803
12/30/21 09:06 AM
12/30/21 09:06 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Looked for Brian Smith on facebook, there are 100's LOL
As far as a cam, all I know is when I went back with the "regular" headers on the "new" cam, I lost power. The merge collectors are helping the exhaust. If you had a carb and changed headers, you would never "see" any difference because the carb would add the extra fuel. Calvin Easton said besides changing the cam profile, some NASCAR teams used a smaller exhaust valve, which allowed an even bigger intake valve.
Joe
Without Data, you’re just another guy with an opinion.
Re: Header design, merge collectors? [Re: sr4440] #2999812
12/30/21 09:41 AM
12/30/21 09:41 AM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by sr4440
I switch from a regular 2.25 26in header to a 12in 1st step 2.125 and a 2nd 12 inch 2.25 with a 3 1/2 inch merge, to 3 to 4 inch cone. When I put the merge headers on an B1 MFI 512, the engine went dead lean. The fuel pressure was the same, the engine was just moving a lot more air or pulling the initial fuel through the cylinder. I ended up putting more fuel in it to get back the HP. Went from a .920 BSFC to 1.105 BSFC to make the same power. The cam was a 282 292 with a 112 LSA. So I ordered a new cam 282 284 112 LSA. The new came didn't make any more HP, but it did make about 20ft more torque, up to peak TQ. Has a super flat curve. LOL I wasn't expecting results like that considering how small the exhaust valve is on a b1 head.
Joe
Joe, is this a correct summary. The header change didn't add any peak HP, but helped at and below the torque peak?
Re: Header design, merge collectors? [Re: sr4440] #2999815
12/30/21 09:46 AM
12/30/21 09:46 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Look up Smith Innovation.
Re: Header design, merge collectors? [Re: JERICOGTX] #2999849
12/30/21 11:29 AM
12/30/21 11:29 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Brian is a good guy, sharp character too. He, his Dad and brother were on here years ago, like many others they just faded out.
Re: Header design, merge collectors? [Re: 440Jim] #3000049
12/30/21 06:20 PM
12/30/21 06:20 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Joe
They say a pic is worth a 1000 words, here are the run with the old headers and a 100 pill and the new headers after i added a b%%load of fuel (90 pill). The higher number will be with the merge collectors. The cam change added tq below peak TQ.
Joe
Attached PDF document
new headers.pdf (71 downloads)
Re: Header design, merge collectors? [Re: sr4440] #3000127
12/30/21 09:52 PM
12/30/21 09:52 PM
NC
440Jim Offline
440Jim  Offline
NC
Joe
Thanks for the dyno curves. Is that a comparison of the baseline cam and 2-1/4 headers, compared to the new cam and step headers? Or just the header swap?
Re: Header design, merge collectors? [Re: 440Jim] #3000158
12/30/21 10:57 PM
12/30/21 10:57 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Joe
That was just the header swap and adding fuel to get the power back, same timing.
Joe
Re: Header design, merge collectors? [Re: sr4440] #3002046
01/04/22 05:26 PM
01/04/22 05:26 PM
NC
440Jim Offline
440Jim  Offline
NC
You guys convinced me to change plans and build a step header for my new 572 CID B1 engine.
I had previously bought only 2-1/4" tubes. So I bought some 2-1/8" J-bends.
This pic shows the original test fit of the 2-1/4" tube in the custom flanges I had made locally to fit the porting on my heads,
and also the 2-1/8" tube test fit next to it. The 2-1/4" was really tight, the 2-1/8" were easier to form to the shape. This worked out great.
Re: Header design, merge collectors? [Re: 440Jim] #3002077
01/04/22 06:53 PM
01/04/22 06:53 PM
AndyF Online content
AndyF  Online Content
If you have access to Pipemax you'll be able to get the recommend lengths for each step as well as the collector size and length. If you don't have Pipemax than maybe someone on the board with a copy will run the numbers for you. I'd think that you would want your own copy if you don't have one already since a lot of what you do would fit nicely with the way the program works.
Re: Header design, merge collectors? [Re: 440Jim] #3002151
01/04/22 10:25 PM
01/04/22 10:25 PM
gregsdart Offline OP
Jim, I bought pipemax, can run numbers for you. If you download pipemax, you can fill in all the info, take a picture and send it to me. I can run it and send back info.
Re: Header design, merge collectors? [Re: gregsdart] #3002522
01/06/22 10:00 AM
01/06/22 10:00 AM
Collecters kit showed up today. Merges down to 3.5 then back to 4 inch
Re: Header design, merge collectors? [Re: gregsdart] #3002579
01/06/22 12:48 PM
01/06/22 12:48 PM
Looks interesting. I haven't seen that inner ring before. Wonder what the idea is behind that? Looks like it would block the flow. Maybe that is just a welding fixture?
Re: Header design, merge collectors? [Re: AndyF] #3002581
01/06/22 01:11 PM
01/06/22 01:11 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
^ Yes it's just a fixture for the cone
Nice stuff smile
Re: Header design, merge collectors? [Re: INTMD8] #3002595
01/06/22 01:47 PM
01/06/22 01:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Nice stuff smile
And they pack it like it's fine china. Nice to see someone making nice stuff and caring.
Re: Header design, merge collectors? [Re: gregsdart] #3003824
01/10/22 02:31 PM
01/10/22 02:31 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by gregsdart
The plan is ;. 10 inch 1st step of 2 1/8 16 Ga, 14 inch 2 1/4 for second step, over all 10 inch of collector with a 3 1/2 inch merge, to 3 to 4 inch cone.
Greg,
is that 10" going to be 3.5" valve to flange + 6.5" of actual 2-1/8 pipe from the flange? Or 10" of actual 2-1/8 pipe + 3.5" valve to flange = 13.5" total (PipeMax)
Re: Header design, merge collectors? [Re: 440Jim] #3004229
01/11/22 05:29 PM
01/11/22 05:29 PM
Greg,
13.5 to 14 total length
Re: Header design, merge collectors? [Re: gregsdart] #3004825
01/13/22 10:41 AM
01/13/22 10:41 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice looking stuff Greg! There is a pic that shows the upper corners of the port outlet obstructed by the new flanges. I wouldn't overlook fixing that too. Thanks for sharing.
Re: Header design, merge collectors? [Re: HardcoreB] #3004828
01/13/22 10:56 AM
01/13/22 10:56 AM
I bought a set of flanges pictured on page 1, posted by Jericogtx. Nice catch on the missmatch. I will have to fix that. Maybe flip the flanges to make sure they are symmetrical.
Re: Header design, merge collectors? [Re: gregsdart] #3004832
01/13/22 11:16 AM
01/13/22 11:16 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Flipping them is exactly what I thought I'd try first!
Page 2 of 3 1 2 3
