Roller Cam Shopping #2999697
12/29/21 09:20 PM
12/29/21 09:20 PM
Mid TN
2BblHarold Offline OP
Mid TN
After a teardown and finding my lifters are flat, I'm looking for your thoughts on a good roller cam.
318, LD4B, Holley 600, 9/1 comp, 302 heads, 2.94 rear, auto, stock converter, '68 Coronet. Local cruiser with good hwy manners, tho a moderately lumpy idle won't hurt my feelings. Thanks!
Re: Roller Cam Shopping [Re: 2BblHarold] #2999701
12/29/21 09:24 PM
12/29/21 09:24 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don’t know how the SB Mopar roller cam core situation is at the moment, but it’s been pretty bleak all year so far.
It might end up coming down to buying from wherever they have a core to grind.
Re: Roller Cam Shopping [Re: fast68plymouth] #2999852
12/30/21 11:39 AM
12/30/21 11:39 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I hope this isn't off topic but the thought of running a steel billet roller on the street scares me. Would it be possible to buy a big cast flat tappet cam and regrind it to a street roller profile?
Re: Roller Cam Shopping [Re: 6PakBee] #2999919
12/30/21 01:33 PM
12/30/21 01:33 PM
gregsdart Offline
gregsdart  Offline
For that you could call a couple of cam companies, as well as a cam regrinder to see what can be done, what cores would work, etc. I would guess a used performance cam would give you better options for regrinding.
Re: Roller Cam Shopping [Re: gregsdart] #2999992
12/30/21 03:56 PM
12/30/21 03:56 PM
North Dakota
North Dakota
I agree that would be the definite route. But when I am having a brain fart I like to just throw it out there. Three basic types of responses, 1) yes, it will work, 2) you should check with a vendor and see (this is the class your response fits into), and 3) that is the stupidest thing I've ever read, are you building model airplanes without enough ventilation?
When the time comes closer I'd probably call someone like Hughes for advice. Thanks for the response. up
Re: Roller Cam Shopping [Re: 6PakBee] #3000064
12/30/21 07:07 PM
12/30/21 07:07 PM
Mid TN
Mid TN
Ugg! I didn't realize just how messed up the cam world is with the supply chain woes. I haven't located anything in stock, but some suppliers are taking there best guess at shipping dates, April and beyond. That has me thinking to throw a Summit cam in while being as careful as I can on break in. At least I can be up in a week or so.
Re: Roller Cam Shopping [Re: 2BblHarold] #3000105
12/30/21 08:53 PM
12/30/21 08:53 PM
Try contacting John Partridge at Bullet racing cams @ 662-893-5670 up scope twocents
Re: Roller Cam Shopping [Re: 2BblHarold] #3000112
12/30/21 09:18 PM
12/30/21 09:18 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
I ended up buying an off the shelf hughes hydraulic roller, was gonna have dwayne porter grind me one but i never heard back from him, he was checking to see if any cores were available. im not going racing with this car, so an off the shelf will be just fine.
Re: Roller Cam Shopping [Re: Cab_Burge] #3000116
12/30/21 09:23 PM
12/30/21 09:23 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
What year block is it? 302 heads makes it sound like an 80's if those heads came with it. If it's a factory roller block then you can grab a factory roller from a bone yard and have it reground. Or, since you're probaby looking at a complete rebuild anyways just grab a roller motor.
Even if stuff is in stock you're going to be looking $1500 to retrofit a non-roller block between the cam, lifters, springs and rockers. Maybe more.
Re: Roller Cam Shopping [Re: MarkZ] #3000129
12/30/21 10:01 PM
12/30/21 10:01 PM
Mid TN
Mid TN
This is a '68 block, I put the 302 heads on it a few years ago. I recently lost a cylinder, went digging, and found my flattened lifters.
Anyhoo, I just ordered a new comp cams kit. I'm out a few hundred but I'll be up a lot sooner than going the roller route.
