Roller Cam Shopping
#2999697
12/29/21 09:20 PM
12/29/21 09:20 PM
Posts: 66 Mid TN
2BblHarold
Mid TN
After a teardown and finding my lifters are flat, I'm looking for your thoughts on a good roller cam. 318, LD4B, Holley 600, 9/1 comp, 302 heads, 2.94 rear, auto, stock converter, '68 Coronet. Local cruiser with good hwy manners, tho a moderately lumpy idle won't hurt my feelings. Thanks!
Re: Roller Cam Shopping
[Re: 2BblHarold]
#2999701
12/29/21 09:24 PM
12/29/21 09:24 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don’t know how the SB Mopar roller cam core situation is at the moment, but it’s been pretty bleak all year so far.
It might end up coming down to buying from wherever they have a core to grind.
[Re: fast68plymouth]
#2999852
12/30/21 11:39 AM
12/30/21 11:39 AM
Posts: 10,737 North Dakota
6PakBee
North Dakota
I hope this isn't off topic but the thought of running a steel billet roller on the street scares me. Would it be possible to buy a big cast flat tappet cam and regrind it to a street roller profile?
[Re: 6PakBee]
#2999919
12/30/21 01:33 PM
12/30/21 01:33 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
For that you could call a couple of cam companies, as well as a cam regrinder to see what can be done, what cores would work, etc. I would guess a used performance cam would give you better options for regrinding.
[Re: gregsdart]
#2999992
12/30/21 03:56 PM
12/30/21 03:56 PM
6PakBee
North Dakota
For that you could call a couple of cam companies, as well as a cam regrinder to see what can be done, what cores would work, etc. I would guess a used performance cam would give you better options for regrinding. I agree that would be the definite route. But when I am having a brain fart I like to just throw it out there. Three basic types of responses, 1) yes, it will work, 2) you should check with a vendor and see (this is the class your response fits into), and 3) that is the stupidest thing I've ever read, are you building model airplanes without enough ventilation? When the time comes closer I'd probably call someone like Hughes for advice. Thanks for the response.
[Re: 2BblHarold]
#3000112
12/30/21 09:18 PM
12/30/21 09:18 PM
Posts: 1,236 Fairview Tennessee
SV_MOPARS
Fairview Tennessee
I ended up buying an off the shelf hughes hydraulic roller, was gonna have dwayne porter grind me one but i never heard back from him, he was checking to see if any cores were available. im not going racing with this car, so an off the shelf will be just fine.
[Re: Cab_Burge]
#3000116
12/30/21 09:23 PM
12/30/21 09:23 PM
Posts: 4,443 Michigan
MarkZ
Worthy
Worthy
What year block is it? 302 heads makes it sound like an 80's if those heads came with it. If it's a factory roller block then you can grab a factory roller from a bone yard and have it reground. Or, since you're probaby looking at a complete rebuild anyways just grab a roller motor.
Even if stuff is in stock you're going to be looking $1500 to retrofit a non-roller block between the cam, lifters, springs and rockers. Maybe more.
