440 fuel pump install questions #2999588
12/29/21 04:49 PM
12/29/21 04:49 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
Having some install problems with fuel pump. Pump is installed (2x) but is not pumping gas. Not sure if I have pump arm positioned correctly on rod. Or pump rod is not fully retracted into block, and I am missing getting solid contact rod-to-arm. So here goes: 1. how much of fuel pump rod, when fully retracted, protrudes past block? 2. how much cranking on the engine before I see fuel coming out of pump? Replaced factory pump rod (wore to 3.17) with Comp 4646.
Thanks, Ferd
Re: 440 fuel pump install questions [Re: fal3] #2999611
12/29/21 05:57 PM
12/29/21 05:57 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
should pump withen a few seconds of cranking, not sure about length 1/2 inch maybe, should be no gap between lever and rod
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 440 fuel pump install questions [Re: 440lebaron] #2999703
12/29/21 09:26 PM
12/29/21 09:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The fuel pump rods have been known to wear off a bit over time, some were a little soft from the factory.
I don't remember the correct length, but it was posted on this site at one point, a few years back.
You probably need to retitle this thread asking about the fuel pump rod length. Gene
Re: 440 fuel pump install questions [Re: poorboy] #2999716
12/29/21 09:45 PM
12/29/21 09:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not to be offensive but I have never heard of the factory FP pushrods being to soft only aftermarket ones twocents beer
Re: 440 fuel pump install questions [Re: TJP] #2999749
12/29/21 11:18 PM
12/29/21 11:18 PM
Andrewh Offline
Andrewh  Offline
have you tried from a gas can instead of the gas tank?
just in case you have some other issue?
Re: 440 fuel pump install questions [Re: TJP] #2999753
12/29/21 11:25 PM
12/29/21 11:25 PM
Kirkland, Washington
Pacnorthcuda Offline
Mopar Performance (purchased from Chrysler dealer) were crap in the 90’s.
Re: 440 fuel pump install questions [Re: fal3] #2999819
12/30/21 10:10 AM
12/30/21 10:10 AM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
AndrewH-going to hook-up vacuum pump to check gas line from tank for obstructions as a precaution.
Beginning to think new fuel pump bad.
Re: 440 fuel pump install questions [Re: Pacnorthcuda] #2999836
12/30/21 11:05 AM
12/30/21 11:05 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Those were repackaged aftermarket ones, not "factory" ones.
Re: 440 fuel pump install questions [Re: Pacnorthcuda] #2999916
12/30/21 01:29 PM
12/30/21 01:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Hmm First I've heard of that. I bought several in 93 and they were all fine. Might have been older stock as they were in yellowed chrysler packaging with no reference to mopar performance shruggy
Re: 440 fuel pump install questions [Re: TJP] #2999971
12/30/21 02:50 PM
12/30/21 02:50 PM
moparx Offline
moparx  Offline
i just measured a "good" factory fuel pump pushrod and got the length to be 3.224 long.
this particular rod came from a high mileage [around 80k if i recollect right] 440.
i deemed it necessary to add to my "stuff", so it must be good. biggrin
beer
Re: 440 fuel pump install questions [Re: moparx] #3000004
12/30/21 04:09 PM
12/30/21 04:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe the cam along with the push rod was worn????
Re: 440 fuel pump install questions [Re: mopars4ever] #3000011
12/30/21 04:27 PM
12/30/21 04:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure you got he pump arm under the rod? I always grease the rod and turn the engine over until the rod is completely up. The grease keeps the rod from dropping down.
Re: 440 fuel pump install questions [Re: stumpy] #3000020
12/30/21 04:48 PM
12/30/21 04:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would think the pump would not go in all the way if the rod was still down but it has been a long time since I messed with a big block so maybe I`m wrong?.
Re: 440 fuel pump install questions [Re: fal3] #3000021
12/30/21 04:50 PM
12/30/21 04:50 PM
Pasadena, Texas
fal3 Offline OP
fal3  Offline OP
Pasadena, Texas
Update. Removed new pump and re-installed old; same problem no fuel pumped. I removed the new pump rod CCA 4646 and measured length; new rod is 3.218 (advertised 2.24 length); old rod measured 3.17. Factory specs are 3.25. I'm not keen on small tolerance numbers, and the impact they have on engine performance. So, the question is does that .022 difference (cca4646 actual measurement v. advertised or .032 difference (factory v. cca646) really have a big impact on fuel pushed through the system? I'm leaning towards "no", but will concede am out of my element and am wrong.
Stumpy- I've been wondering the same. Do I have the arm fully contacting the rod? When I first installed new pump, you could see via access hole, the pump arm going moving, but I'm unsure as to how much swing the arm has.
Re: 440 fuel pump install questions [Re: fal3] #3000037
12/30/21 05:48 PM
12/30/21 05:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not sure if this is your problem but I had a car that was not getting suction from a cracked rubber fuel line. Might be worth a check. Sometimes you can`t visually see the cracks in the hose.
Re: 440 fuel pump install questions [Re: mopars4ever] #3000043
12/30/21 06:02 PM
12/30/21 06:02 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
This is what I'd do next. Run a NEW length of fuel hose to a gas can instead of the tank. See if the new pump will pull fuel out of the can.
Re: 440 fuel pump install questions [Re: fal3] #3000107
12/30/21 08:56 PM
12/30/21 08:56 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Where did you get your new pump from? I've had new ones from Autozone be junk right out of the box. Went through this same thing last summer. Determined my old pump was bad, so, I bought a new one and still couldn't get it to run.
It would run just fine pouring fuel in the carb. Took the new pump back and got another one, 440 fired right off.
Re: 440 fuel pump install questions [Re: fal3] #3000114
12/30/21 09:19 PM
12/30/21 09:19 PM
I have nine used Mopar pushrods from B,RB and 426 Street hemi motors removed from 1963 up to mid 1970 motors.
The shortest one is3.205 and the longest one measured with the same set of dial calipers is 3.227 shruggy
The shortest one show wear on both ends, the longest one show contact on both ends but no visible wear shruggy
IHTHs
I have tested BB mechanical fuel pumps by hand off the motor with a hose in a safe liquid like mineral spirits or diesel fuel hooked up to the inlet side to make sure they work scope wrench up
There is always a reason parts don't work work Figuring out what is causing the issue is the fun part, sometimes whistling
Re: 440 fuel pump install questions [Re: Cab_Burge] #3000154
12/30/21 10:43 PM
12/30/21 10:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Hooking a vacuum gauge to the inlet port is a whole lot easier and quicker to determine if the pump is pulling. One can also use the same gauge to the check the pressure out. Also useful for many other things and CHEAP
Re: 440 fuel pump install questions [Re: fal3] #3000163
12/30/21 11:05 PM
12/30/21 11:05 PM
Chicago
PurpleBeeper Offline
Chicago
Screw it....buy a new fuel pump rod too. It's hard to get the pump installed wrong. I remember just having to bump the motor over sometimes to get the fuel pump rod off the fuel pump cam lobe to slide the pump in. I bet you do have a bad new pump unless the fuel line/filter is super blocked off like you mentioned.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
