Head casting #2999238
12/28/21 05:22 PM
12/28/21 05:22 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
looking for heads for my nhra stocker 400 b casting 4120187 what is it?
also can use 4006452 76'-78 400-440, 3769975 75'400-440
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Head casting [Re: 440lebaron] #2999241
12/28/21 05:35 PM
12/28/21 05:35 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Absolutely use the 452.
Re: Head casting [Re: 440lebaron] #2999320
12/28/21 09:33 PM
12/28/21 09:33 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
If you can't find 452 heads locally, I have a stack of them, and a couple sets of the police car/RV heads with the extra steam holes, if you need them. S/F....Ken M
Re: Head casting [Re: 440lebaron] #2999377
12/29/21 01:31 AM
12/29/21 01:31 AM
Before you decide make sure and have all eight ports flowed as well as any replacement heads NHRA accepts, me thinks there may be a Edelbrock head acceptable scope
I have several sets of the stock 400 heads, not sure which casting numbers though shruggy
PM me if your interested in a set cheap grin
Re: Head casting [Re: 440lebaron] #2999504
12/29/21 01:16 PM
12/29/21 01:16 PM
Boise
Moparteacher Offline
Boise
FWIW, a few things I remember when I was researching heads for a 383 stocker:
The 452 casting has the best low lift numbers.
Milling the intake face lowers the intake volume and makes room to......ahem.....well, customize the port and maintain the NHRA intake volume specification. NHRA states a limit to how far it can be milled. It cannot go into the valve cover bolt holes.
A 45 degree seat on the intake is NOT the angle you want. A 30 degree seat flows better at low lift numbers and may be preferred.
The Edelbrock acceptable head comes with a weight penalty, and has the wrong valve sizes, thus different valves and seats may be required.
Disclaimer: It's been a few years and the rules may have changed, and all this info may be nonsense.
You may be able to purge some better info on Classracer.com
Re: Head casting [Re: Moparteacher] #2999566
12/29/21 03:31 PM
12/29/21 03:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My advice is to just look for some 452’s that haven’t been touched yet........ that have minimal core shift, and the valve seats aren’t all pounded out.
Re: Head casting [Re: fast68plymouth] #2999789
12/30/21 07:24 AM
12/30/21 07:24 AM
Canada
Max Weg Offline
Max Weg  Offline
Canada
To be competitive in Stock Eliminator your best bang for the buck is to use a reputable cylinder head and intake shop that works on these engines for these classes. You will be wasting your money and effort and getting poor results otherwise.
Max Weg
Re: Head casting [Re: Max Weg] #3000330
12/31/21 03:15 PM
12/31/21 03:15 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
You might want to check with Don Little on the BB heads. The Eddy heads will take some work as they have smaller valve stem guides (need enlarged to .375") and they have seats for larger valves. I think they come unmachined, not sure if the throats are too large for stock size valves. I think the ports have too many CCs, so need the flanges need milled back. As stated, probably cheaper to find a good head guy that knows how to make them run fast. I'd figure $20k for the engine costs, maybe more.
Floyd Lippencott IV
Re: Head casting [Re: mr_340] #3000353
12/31/21 04:07 PM
12/31/21 04:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
I don’t think the nhra approved Ede BB head has been available for a while.
