Re: Header design, merge collectors?
[Re: gregsdart]
#2999795
12/30/21 08:33 AM
12/30/21 08:33 AM
Posts: 10,035 MN
JERICOGTX
MN
Brian Smith makes those header flanges. He used to be a member here, but have not seen him in a long time. He is on Facebook though. You will not find a nicer header collector piece than he makes.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2999803
12/30/21 09:06 AM
12/30/21 09:06 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Brian Smith makes those header flanges. He used to be a member here, but have not seen him in a long time. He is on Facebook though. You will not find a nicer header collector piece than he makes. Looked for Brian Smith on facebook, there are 100's LOL As far as a cam, all I know is when I went back with the "regular" headers on the "new" cam, I lost power. The merge collectors are helping the exhaust. If you had a carb and changed headers, you would never "see" any difference because the carb would add the extra fuel. Calvin Easton said besides changing the cam profile, some NASCAR teams used a smaller exhaust valve, which allowed an even bigger intake valve. Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2999812
12/30/21 09:41 AM
12/30/21 09:41 AM
Posts: 16,928 NC
440Jim
NC
I switch from a regular 2.25 26in header to a 12in 1st step 2.125 and a 2nd 12 inch 2.25 with a 3 1/2 inch merge, to 3 to 4 inch cone. When I put the merge headers on an B1 MFI 512, the engine went dead lean. The fuel pressure was the same, the engine was just moving a lot more air or pulling the initial fuel through the cylinder. I ended up putting more fuel in it to get back the HP. Went from a .920 BSFC to 1.105 BSFC to make the same power. The cam was a 282 292 with a 112 LSA. So I ordered a new cam 282 284 112 LSA. The new came didn't make any more HP, but it did make about 20ft more torque, up to peak TQ. Has a super flat curve. LOL I wasn't expecting results like that considering how small the exhaust valve is on a b1 head.
Joe
Joe, is this a correct summary. The header change didn't add any peak HP, but helped at and below the torque peak?
[Re: sr4440]
#2999815
12/30/21 09:46 AM
12/30/21 09:46 AM
Posts: 10,035 MN
JERICOGTX
MN
Brian Smith makes those header flanges. He used to be a member here, but have not seen him in a long time. He is on Facebook though. You will not find a nicer header collector piece than he makes. Looked for Brian Smith on facebook, there are 100's LOL Look up Smith Innovation.
69 GTX
68 Road Runner
[Re: 440Jim]
#3000049
12/30/21 06:20 PM
12/30/21 06:20 PM
sr4440
Central TEXAS!!!!
Joe
Joe, is this a correct summary. The header change didn't add any peak HP, but helped at and below the torque peak? They say a pic is worth a 1000 words, here are the run with the old headers and a 100 pill and the new headers after i added a b%%load of fuel (90 pill). The higher number will be with the merge collectors. The cam change added tq below peak TQ. Joe
[Re: sr4440]
#3000127
12/30/21 09:52 PM
12/30/21 09:52 PM
Posts: 16,928 NC
440Jim
NC
Joe Thanks for the dyno curves. Is that a comparison of the baseline cam and 2-1/4 headers, compared to the new cam and step headers? Or just the header swap?
[Re: 440Jim]
#3000158
12/30/21 10:57 PM
12/30/21 10:57 PM
sr4440
Central TEXAS!!!!
Joe Thanks for the dyno curves. Is that a comparison of the baseline cam and 2-1/4 headers, compared to the new cam and step headers? Or just the header swap? That was just the header swap and adding fuel to get the power back, same timing. Joe
[Re: 440Jim]
#3002151
01/04/22 10:25 PM
01/04/22 10:25 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You guys convinced me to change plans and build a step header for my new 572 CID B1 engine. I had previously bought only 2-1/4" tubes. So I bought some 2-1/8" J-bends. This pic shows the original test fit of the 2-1/4" tube in the custom flanges I had made locally to fit the porting on my heads, and also the 2-1/8" tube test fit next to it. The 2-1/4" was really tight, the 2-1/8" were easier to form to the shape. This worked out great. Jim, I bought pipemax, can run numbers for you. If you download pipemax, you can fill in all the info, take a picture and send it to me. I can run it and send back info.
[Re: AndyF]
#3002581
01/06/22 01:11 PM
01/06/22 01:11 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
^ Yes it's just a fixture for the cone Nice stuff
[Re: INTMD8]
#3002595
01/06/22 01:47 PM
01/06/22 01:47 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
^ Yes it's just a fixture for the cone Nice stuff And they pack it like it's fine china. Nice to see someone making nice stuff and caring.
[Re: gregsdart]
#3003824
01/10/22 02:31 PM
01/10/22 02:31 PM
Posts: 16,928 NC
440Jim
NC
The plan is ;. 10 inch 1st step of 2 1/8 16 Ga, 14 inch 2 1/4 for second step, over all 10 inch of collector with a 3 1/2 inch merge, to 3 to 4 inch cone. Greg, is that 10" going to be 3.5" valve to flange + 6.5" of actual 2-1/8 pipe from the flange? Or 10" of actual 2-1/8 pipe + 3.5" valve to flange = 13.5" total (PipeMax)
[Re: 440Jim]
#3004229
01/11/22 05:29 PM
01/11/22 05:29 PM
gregsdart
The plan is ;. 10 inch 1st step of 2 1/8 16 Ga, 14 inch 2 1/4 for second step, over all 10 inch of collector with a 3 1/2 inch merge, to 3 to 4 inch cone. Greg, is that 10" going to be 3.5" valve to flange + 6.5" of actual 2-1/8 pipe from the flange? Or 10" of actual 2-1/8 pipe + 3.5" valve to flange = 13.5" total (PipeMax) 13.5 to 14 total length
[Re: HardcoreB]
#3004828
01/13/22 10:56 AM
01/13/22 10:56 AM
gregsdart
Nice looking stuff Greg! There is a pic that shows the upper corners of the port outlet obstructed by the new flanges. I wouldn't overlook fixing that too. Thanks for sharing. I bought a set of flanges pictured on page 1, posted by Jericogtx. Nice catch on the missmatch. I will have to fix that. Maybe flip the flanges to make sure they are symmetrical.
