4.500 inch bore B1 pump gas pistons, which brand #2998106
12/24/21 04:01 AM
12/24/21 04:01 AM
Cab_Burge Offline OP
I need to order some pump gas pistons for my KB wedge 572 C.I. (4.500x4.500) B1 build, I'm debating between Diamond, Ross or maybe CP. I'm not trying to make an all out drag race or any type of race motor so the trick of the day is not needed.
I'm thinking 1/16,1/16, 3/16 ring sizes with standard tension oil rings and maybe a better 2nd ring like a Napier design.
Who do you B1 guys like for this type of piston?
All help appreciated uphelp
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: Cab_Burge] #2998115
12/24/21 07:52 AM
12/24/21 07:52 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
440source now has B1 pistons
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: pittsburghracer] #2998313
12/25/21 02:38 AM
12/25/21 02:38 AM
I've talk to KB Icon,and Ross so far.
KB, United Machine doesn't make a reverse dome B1 piston so far, flat top with valve reliefs only whiney
I use to be on a deal with Diamond, Arias, SRP, Comp Cams and several others but with all the corporate buys out and my lack of volume sells this last year I'm not sure who to use now confused
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: pittsburghracer] #2998325
12/25/21 08:56 AM
12/25/21 08:56 AM
NY
B1duster Offline
B1duster  Offline
NY
A shelf piston, really ???
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: Cab_Burge] #2998328
12/25/21 09:23 AM
12/25/21 09:23 AM
Boise
Moparteacher Offline
Boise
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: Moparteacher] #2998333
12/25/21 09:51 AM
12/25/21 09:51 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Just ordered a set from Diamond 4 week delivery
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: challenger1320] #2998334
12/25/21 09:55 AM
12/25/21 09:55 AM
NC
440Jim Offline
440Jim  Offline
NC
What was the cost?
With or without rings?
Pin wall thickness?
Extra $ features? (skirt coating, crown coating, gas ported, lightened, etc)
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: B1duster] #2998356
12/25/21 11:56 AM
12/25/21 11:56 AM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: Cab_Burge] #2998403
12/25/21 03:28 PM
12/25/21 03:28 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Cab, have you tried Icon Pistons? My brother works there in tech & sales. Its UEM 1-800-648-7970 ext. 159 Name is Glen
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: merpar] #2998419
12/25/21 04:45 PM
12/25/21 04:45 PM
I thought you were Glenn blush I did talk to him about what they have, no street pistons for B1 whiney
I've talk to him and his son also about other pistons up
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: pittsburghracer] #2998518
12/26/21 12:48 AM
12/26/21 12:48 AM
NY
B1duster Offline
B1duster  Offline
NY
Wow, look at that, so that’s a $600 upgrade on a kit, like $1200 for them
Re: 4.500 inch bore B1 pump gas pistons, which brand [Re: Cab_Burge] #2998569
12/26/21 11:51 AM
12/26/21 11:51 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Use Mahle rings only, have a custom piston made out of 4032 material, and set them up at .0035” piston to wall clearance measured at the largest part of the skirt.
