clutch adjusment? #2998243
12/24/21 05:19 PM
12/24/21 05:19 PM
N.Y.
sixpacksteve Offline OP
N.Y.
i have a 78 dodge 6 cyl.4 speed od. changed the clutch used a clutch that had 200 miles on it.
the clutch wont totally disengage so it wont shift.
toke back apart and noticed the adjustment screws not the same.
Is there a proper way to set the clutch with specs or something?
Hell Hath No Fury Like Mine
Re: clutch adjusment? [Re: sixpacksteve] #2998716
12/26/21 09:49 PM
12/26/21 09:49 PM
Chicago
PurpleBeeper Offline
Chicago
If the clutch won't totally disengage.....maybe the disk is in there backwards? On a V8 that can happen and it will act just like you describe...ask me how I know
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: clutch adjusment? [Re: PurpleBeeper] #2998723
12/26/21 10:24 PM
12/26/21 10:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What he said wink If you start playing with the adjuster on the PP you are liable to really cause issues. Can you drop the inspection cover for a look see ? twocents
Re: clutch adjusment? [Re: TJP] #2998731
12/26/21 10:55 PM
12/26/21 10:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If it turns out that your pressure plate does need adjusting any competent clutch shop can do it. But basically, the fingers have to be adjusted to touch the throw out bearing at the same time, the screws end up where they end up.
