4.500 inch bore B1 pump gas pistons, which brand
#2998106
12/24/21 04:01 AM
12/24/21 04:01 AM
Posts: 43,283 Bend,OR USA
Cab_Burge
I need to order some pump gas pistons for my KB wedge 572 C.I. (4.500x4.500) B1 build, I'm debating between Diamond, Ross or maybe CP. I'm not trying to make an all out drag race or any type of race motor so the trick of the day is not needed. I'm thinking 1/16,1/16, 3/16 ring sizes with standard tension oil rings and maybe a better 2nd ring like a Napier design. Who do you B1 guys like for this type of piston? All help appreciated
Re: 4.500 inch bore B1 pump gas pistons, which brand
[Re: Cab_Burge]
#2998115
12/24/21 07:52 AM
12/24/21 07:52 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
440source now has B1 pistons
[Re: pittsburghracer]
#2998313
12/25/21 02:38 AM
12/25/21 02:38 AM
Cab_Burge
I've talk to KB Icon,and Ross so far. KB, United Machine doesn't make a reverse dome B1 piston so far, flat top with valve reliefs only I use to be on a deal with Diamond, Arias, SRP, Comp Cams and several others but with all the corporate buys out and my lack of volume sells this last year I'm not sure who to use now
#2998325
12/25/21 08:56 AM
12/25/21 08:56 AM
Posts: 3,023 NY
B1duster
NY
A shelf piston, really ???
[Re: challenger1320]
#2998334
12/25/21 09:55 AM
12/25/21 09:55 AM
Posts: 16,930 NC
440Jim
NC
Just ordered a set from Diamond 4 week delivery What was the cost? With or without rings? Pin wall thickness? Extra $ features? (skirt coating, crown coating, gas ported, lightened, etc)
[Re: B1duster]
#2998356
12/25/21 11:56 AM
12/25/21 11:56 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
[Re: merpar]
#2998419
12/25/21 04:45 PM
12/25/21 04:45 PM
Cab_Burge
I thought you were Glenn I did talk to him about what they have, no street pistons for B1 I've talk to him and his son also about other pistons
#2998518
12/26/21 12:48 AM
12/26/21 12:48 AM
Posts: 3,023 NY
B1duster
NY
A shelf piston, really ??? Wow, look at that, so that’s a $600 upgrade on a kit, like $1200 for them
