Re: 66 B Body radio delete
[Re: topside]
#2997013
12/20/21 12:18 PM
12/20/21 12:18 PM
Posts: 21,403 It's a dry heat
gtx6970
It's a dry heat
Pretty sure you need an original part for either of those if you want it "correct". Not aware of any reproductions. Correct. And I think they are body style specific between Dodge and Plymouth. There 'was' a heater delete plate for a Plymouth on ebay a while back. Radio delete plates are not terribly difficult to find
[Re: cudaman1969]
#2997078
12/20/21 03:56 PM
12/20/21 03:56 PM
gtx6970
It's a dry heat
One thing I found out on my 66 Belvedere was the chrome around the bottom of dash is delete plate specific. Meaning the plate won’t fit if you had a radio, plate is bigger. I picked up another dash (with radio) l for the chrome piece and it won’t fit. Can’t trim the plate or the chrome Is there a thinned down area on the trim or an actual thinner trim piece overall ???? My car is radio delete. And didnt know of a unique trim piece below it.
[Re: gtx6970]
#2997081
12/20/21 04:23 PM
12/20/21 04:23 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
It’s the opening size where it’s straight then curves down and runs under plate. Corners touch. Couldn’t figure what was wrong untill I laid old one on top of new one. Why they did that I have no clue, maybe vender messed up. Now I have to get original re-chromed
[Re: cudaman1969]
#2997130
12/20/21 08:25 PM
12/20/21 08:25 PM
Posts: 1,400 Wi.
old_racer
Wi.
https://www.redvenomrepros.comI bought a 64 plymouth heater delete plate from these guys, nice quality. they have the radio delete plates also in plastic. my 67 belvedere radio delete plate is metal tho but it's original maybe being plastic you could trim it for the chrome strip?
