Anyone seen an A-100 converted to 4wd? Pics? #2996707
12/19/21 12:28 PM
12/19/21 12:28 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If anyone has seen one, I would love to see photos.
Thanks!
Re: Anyone seen an A-100 converted to 4wd? Pics? [Re: Alaskan_TA] #2996723
12/19/21 01:31 PM
12/19/21 01:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Easy find. 4x4
Re: Anyone seen an A-100 converted to 4wd? Pics? [Re: NITROUSN] #2996754
12/19/21 03:16 PM
12/19/21 03:16 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I was interested in actual sightings that could lead to some build details.
Dana 44 front end or ? Etc.
Re: Anyone seen an A-100 converted to 4wd? Pics? [Re: Alaskan_TA] #2996803
12/19/21 07:50 PM
12/19/21 07:50 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Pfft. 4X4 was sooooo yesterday. wink
(I pulled these images from a YouTube video a year or so ago)
Back to topic, how the heck would you shift the transfer case? It would almost have to be electronic control. work
John
Re: Anyone seen an A-100 converted to 4wd? Pics? [Re: SattyNoCar] #2996834
12/19/21 09:20 PM
12/19/21 09:20 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Since it's already leaf springs, a live front axle would be easy. Blocks in rear to level. Transfer case might be tricky a divorce case shouldn't be too hard to add.
T case linkage would be the easiest part of the conversion l
Would the unibody handle the abuse?
Angry white pureblood male
Re: Anyone seen an A-100 converted to 4wd? Pics? [Re: ruderunner] #2996906
12/20/21 12:50 AM
12/20/21 12:50 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It probably wouldn't be a great thing to do mud bogs or those monster truck jumps with, and I probably wouldn't put a snow plow on one, but as far as just being a 4x4 truck or van, I wouldn't see a problem.
If you want, it probably would be easier to set the tub onto an already built 4x4 chassis, then you could get as serious as you dare to go.
Re: Anyone seen an A-100 converted to 4wd? Pics? [Re: poorboy] #2996963
12/20/21 09:34 AM
12/20/21 09:34 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Years ago someone posted theirs on sweptline.org, but the pictures are gone. I think the position of the transfer case would be similar to a Forward Control Jeep.
From their post:
Quote
I have a 68 A100 4x4. See pics.. 318/ 3spd... dana 27 front/rear axles from a scout, dana 300 t-case. works well but i want to find some later model scout axles.. dana 44 rear and dana 30 front.
1970 Dodge d100/eventually going on a 77 D100 frame
