Manual Steering box and Borgeson 11/16-36x3/4 #2995158
12/14/21 07:55 AM
12/14/21 07:55 AM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
Hello,
Will remove my power steering and bolt an old manual alum box in my Satellite -68.
Was there different input shafts in the manual aluminium boxes? If just one, would a Borgeson part nr 012564 work best? Splines 11/16-36x3/4.
Can my my own adapter in a smal Lathe in my garage, recently bought a mill to.
Thanks for reading!
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: RT540] #2995380
12/14/21 10:11 PM
12/14/21 10:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the manual steering boxes were 3" or 4" shorter (maybe more, don't remember for sure anymore) then the power steering boxes. You have to make up the difference between the box and the steering column.
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: poorboy] #2995421
12/15/21 01:46 AM
12/15/21 01:46 AM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
Yes I know and did write that I will make my own adapter with a Lathe and mill.
The question was about the Borgeson splines and diameter?
Maybe this question should have been asked in the race forum?
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: Moparteacher] #2995550
12/15/21 04:55 PM
12/15/21 04:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: Sniper] #2995564
12/15/21 05:30 PM
12/15/21 05:30 PM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
I would like to just buy a Borgeson universal joint. Just so I buy the correct one.
Already have an old manual steering box. Should the shaft be 11/16 or 3/4 diameter on the outside of the splines?
According to the Firmfeel adapter, it should be a 3/4-36 splines?
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: RT540] #2995566
12/15/21 05:39 PM
12/15/21 05:39 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Borgeson has that info in their catalog.
https://www.borgeson.com/catalog.html#
They also clearly state "The 5/8”-36 Chrysler is not interchangeable with 5/8”-36"
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: Sniper] #2995781
12/16/21 11:53 AM
12/16/21 11:53 AM
moparx Offline
moparx  Offline
what is the difference between the two 5/8-36 splines ?
beer
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: moparx] #2995922
12/16/21 08:40 PM
12/16/21 08:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
From what I've seen, the Mopar spline has one spline not cut into the shaft, so the U joint also has to have that matching missing spline. That spline change on the Mopar shafts was to keep everything in alignment. The generic u joint has all the splines cut. Gene
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: poorboy] #2996116
12/17/21 01:03 PM
12/17/21 01:03 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
how would you cut the splines in a lathe? mopar performance still sells the adapter p4510637, also late model "B" vans had them stock with manual steering
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Manual Steering box and Borgeson 11/16-36x3/4 [Re: poorboy] #2996119
12/17/21 01:09 PM
12/17/21 01:09 PM
moparx Offline
moparx  Offline
thanks Gene ! bow
nothing a trip to the bridgeport won't fix.
i ran into a similar problem with the splines on a mopar steering wheel one time, but i forget what wheel i was going to put on what car.
i solved that problem by using a dremel tool and removing the master [uncut] spline. it didn't take much, as the splines are not very deep.
a dremel tool may even be the answer to the steering box master spline.
beer
